Lunati Drag Race TLR2 in an ls1?
Hey all, got a cam from a buddy of mine and was planning on putting it in my car. 01 trans am stock ls1. I have some stock 243 heads I plan on getting worked. I need to know what all I need to do to get the cam to work with my setup, and if it's worth it. Here are the specs straight off the website: Solid Roller Cam. Special nitrous 11:1+ compres- sion, blower 9:1+ compression, 3500 minimum RPM stall in 350 c.i., light to medium cars. ;Advertised Duration (Int/Exh): 292/306 ;Duration @ .050 (Int/Exh): 264/278 ;Gross Valve Lift (Int/Exh): .660/.667 ;LSA/ICL: 112/108 ;Valve Lash (Int/Exh):.014/.016
The following users liked this post:
99 Black Bird T/A (03-26-2020)
