Summit Ghost Cam installed
Old Mar 28, 2020 | 03:10 PM
kbronSS's Avatar
Default Summit Ghost Cam installed
Drives just like stock, although its untuned still. Itll hold idle in nuetral/park AFTER i drive it a bit. Will have to hold on the tune because of a drop in oil psi which is driving me crazy at the moment. From idle at 35/37 at full operating temp in stock trim, it now idles maybe at 5psi. Cold starts at 35/37, before 60/65.
Old Mar 28, 2020 | 04:32 PM
See if a new pressure sender fixes it. Use Delco.
Old Mar 28, 2020 | 04:39 PM
ddnspider's Avatar
Oil pump replaced during cam install? Oil pickup tube o-ring replaced? Cam retainer plate replaced when can was swapped?
Old Mar 28, 2020 | 04:49 PM
kbronSS's Avatar
Tried two different opsd and both read the same. Oil pump was not touched, retainer plate looked good so we re used it, but i just found out silicon was used on it too. At this point im gonna replace the oil pump and pick up tube, i have a feeling something might have fell thru into the pan since its been super windy out here. Also gonna replace the retainer plate.
Old Mar 28, 2020 | 05:00 PM
ddnspider's Avatar
Good call.
Old Mar 28, 2020 | 05:03 PM
Mavn's Avatar
"I MAID THEESE"
Its a Fun cam N/A, Boosted, Nitrous Etc. Works well in any Combo! hopefully you didn't pop a cam bearing loose on install. keep us updated!
Old Mar 28, 2020 | 05:53 PM
kbronSS's Avatar
This is the first time i see this pic, it was taken when cam went in. Im thinking some of this crap if not all, made its way to the pan and got stuck in the screen.
Old Mar 28, 2020 | 11:29 PM
Ls7colorado's Avatar
Why in the world would you reuse the cam retainer plate??
Old Mar 28, 2020 | 11:46 PM
Rickys2003svt.cobra's Avatar
what engine is this in an 5.7? How would this cam work in an 4.8
Old Mar 29, 2020 | 12:26 AM
kbronSS's Avatar
Because it was in good condition and simply got overlooked as parts were ordered, i was not there when the work was done either.
its in a ls1 i couldnt tell u anything about how it would be on a 4.8
Old Mar 30, 2020 | 07:46 AM
99Silver6.0's Avatar
I wonder if some of that junk has inadvertently gotten stuck in the oil pump relief (sticking slightly open) not allowing the pump to actually build pressure.
Old Mar 30, 2020 | 08:01 AM
im pretty sure the cam retainer plate is leaking........
Old Mar 30, 2020 | 10:59 AM
stockA4's Avatar
I had a 212/218 115lsa in a 4.8 and it drove great but the torque shifts to the right with any cam in a tiny engine so it lost a lot below 4k, although it pulled very good to 7200+
I imagine with a 4k converter and some dome pistons or some crafty headwork that cam would be awesome in a 4.8
Old Mar 30, 2020 | 12:11 PM
kbronSS's Avatar
im hoping thats all it is, everything was fine and im not trying to replace cam bearings just yet lol. Number of things point to just the retainer...just ordered one from summit, since these are the new style plates, 18ftlbs the correct torque on the new sryle?
Old Mar 30, 2020 | 12:48 PM
Majestic9C1's Avatar
I'd get some ARP bolts to go along with it for cheap insurance
Old Mar 30, 2020 | 04:59 PM
01CamaroSSTx's Avatar
This oil pressure issue was brought up in your previous thread: Oil psi low after H/C install
Have you dropped the pan to inspect and replaced the cam retainer plate yet?
Old Mar 30, 2020 | 08:52 PM
kbronSS's Avatar
Waiting on parts
Old Mar 31, 2020 | 06:01 AM
I believe that is correct, but to properly install it you really need the newer allen head bolts that are designed to fit into the recess on the new style plate.
Ive used the hold style bolts before and not had a problem but for the extra $6 or whatever it was for new style bolts its a good idea. Yours may come with them anyways
Old Mar 31, 2020 | 09:51 AM
The Felpro from O'riley's does.
Old Mar 31, 2020 | 02:16 PM
trilkb's Avatar
I did lol, Had no idea it was a cause for low oil psi or couldnt be reused until this very moment! I didnt even change my water pump, I know...dirty.
