LQ4 Questions
Ive heard the weight is between 70-100lbs differance.
I dont know why I havent ever measured before but either way, that is a bit of weight to add over the nose.
But on a corvette I dont think you will really notice it other than the car being probably .5" lower in the front (if that), unless you road race the thing.....
Found it: https://ls1tech.com/forums/generatio...ls-blocks.html
do you modify the suspension if you had a 250lb passenger?
like I said... what do you do with the car???????
or what do you plan to do with the car??
without that information there is no way to answer that question
Don't forget whatever method you are adding boost, is also going to kick up the weight due to hardware (including intercooler, lines, etc.). So include that in the total. To compensate, you'll want stiffer front springs. Probably best if you switch to coil overs so you can adjust the ride height. The extra weight and spring rate will both increase understeer. So you'll want to increase rear spring rate as well, plus stiffer rear sway bar to bring back more neutral handling. If they make an adjustable rear bar, go with that, so you can tune the handling.
