Porting 243 heads
Old Apr 10, 2020 | 03:14 PM
86bucket's Avatar
Default Porting 243 heads
I am porting a set of 243 heads. Using a GM exhaust gasket to mark the area to "raise the roof." Why does it look like I need to open it up so much? What am I doing wrong?
Old Apr 10, 2020 | 05:25 PM
SoCalDave's Avatar
The stock exhaust gasket is actually much larger than the stock exhaust manifold so double check that you don't raise the roof too much.
Old Apr 10, 2020 | 07:03 PM
LLLosingit's Avatar
I don't have a flow bench so I don't have any first hand experience. After watching countless video's on porting 243 heads I pretty much came to the conclusion that there isn't anything to be gained by opening the exhaust port.
Old Apr 10, 2020 | 07:11 PM
86bucket's Avatar
So what gasket is this guy using? Basically trying to do what's at 3:50. My gasket seems giant compared to his? Thanks
Old Apr 10, 2020 | 07:18 PM
SoCalDave's Avatar
243 cylinder head that I raised the roof. This set of 243 heads will go on a C5 and should wake it up nicely. The pictures is not the best still it should show that I raised the roof and still left plenty of material.
Old Apr 10, 2020 | 07:22 PM
SoCalDave's Avatar
https://youtu.be/JAeSqBU6OJI
I'm not sure, but I'm using the exhaust gaskets that came off my '01 Camaro.
Old Apr 10, 2020 | 07:40 PM
86bucket's Avatar
Ok, I get the idiot award for the day. 4:20 answered it lol Like you said also...
Old Apr 11, 2020 | 01:41 PM
omc8's Avatar
It's actually easier to get better results as a percentage on the exhaust ! Stock port is going to flow low 180s ........ good hand port 210 cfm when compared to top cnc programs !
Old Apr 11, 2020 | 02:13 PM
showdog75's Avatar
I'd wager a bet that if you had a flow bench to quantify your results you'd hurt way more than you'll gain by porting without the aid of a flow bench. Bigger is not better.
Old Apr 11, 2020 | 02:21 PM
LLLosingit's Avatar
I'd have to search for the video, I'm not saying there aren't gains to be had overall. The video I watched they did step by step port work and put it on the bench with each change. Bowl blend was a good gain as was working the swirl ramp and guides on both intake and exhaust, Good gains with a good valve job and back cut valves, Unshrouding the valves and port matching were smaller gains but still an improvement if done correctly and can actually hurt flow if taken to far or done incorrectly.
Old Apr 11, 2020 | 09:22 PM
omc8's Avatar
Yes agreed , there are no gains in simply hogging out the port exit or just belling it out behind the guide boss .This being op first set , focus on the areas that will net you the biggest gains A good valve job and bowl blend will net you 70% the results with minimal amount of work .
Old Apr 12, 2020 | 10:16 PM
wannafbody's Avatar
Often a smaller port will have better velocity than a larger port.
Old Apr 12, 2020 | 11:07 PM
01CamaroSSTx's Avatar
I would think just knocking off the rough, raising the roof some and smoothing the exhaust chambers would improve performance. Some good videos on the subject from StreetKillz Video Chronicles
Old Apr 14, 2020 | 10:28 AM
64post's Avatar
Remove lumps and bumps, size reduce obstructions like the guide boss, blend the bowl to valve seat and if your really feeling it, blend the valve seat to the chamber so the transition there is seamless. Don’t make the port bigger, not really necessary. Most bang for the buck is bowl work.
Old Apr 14, 2020 | 01:27 PM
SoCalDave's Avatar
If you want to know the theory behind head porting David Vizard has a few videos and some books on the subject. On Youtube HeadflowInc and David Vizard have the most useful information as to the reasons you should make certain mods to cylinder heads.
Old Apr 16, 2020 | 12:47 PM
omc8's Avatar
I would not recommend his videos as guide for a novice for a number of reasons .His terminology is not accurate , there is no real benefit in removing the hump behind the valve guide boss if a novice starts digging there he could break through real quick and so on !
