Gaskets - Where to get the best bang for the $$
Old Apr 19, 2020 | 04:57 PM
TURBOPOWERED68's Avatar
Question Gaskets - Where to get the best bang for the $$
looking for all gaskets except head gaskets, Where is the place to get good gaskets at the value?
Thanks
Looking at some ebay, summit and keep coming across "Conversion gasket set" even though i am looking for stock replacement . What is the this conversion stuff about?
Thanks
Old Apr 19, 2020 | 11:13 PM
wannafbody's Avatar
I'd do the WS6store.com head gaskets as they are just a bit thinner for a slight compression bump.
Old Apr 22, 2020 | 06:58 PM
omc8's Avatar
Yes WS6store LS1 gaskets .045 best bang for the buck for 3.9 bore !
Old Apr 22, 2020 | 10:32 PM
Ted Kay's Avatar
He asked for "...all gaskets except head gaskets".
eBay is fine. Vendors on here are better. Not sure what they mean by "conversion".
Old Apr 23, 2020 | 12:22 AM
Those are a set used when converting from AFM/DOD to normal lifters and trays, plus valley cover.
Old Apr 23, 2020 | 01:24 AM
Ted Kay's Avatar
Gotcha. I try to stick with the Gen III blocks, Gen IV rods. Just be sure to get a good rear main seal, you really don't want to have to replace that more then once. What do you need gaskets for? Gen IV?
Old Apr 23, 2020 | 06:21 PM
99 LQ4
I already picked up the head gaskets. need everything else.
problem i am having that in just about every search Even by my application i keep getting "Conversion" in product description.
Old Apr 23, 2020 | 07:04 PM
FourthGenCamaro's Avatar
Doesn't matter what it says, this is what is needed to put a '99 LQ4 together.
FEL-CS9284
