Let's talk about failed piston ring lands
Old Apr 23, 2020 | 07:42 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Let's talk about failed piston ring lands
What causes an LS1 ring land to fail?
How common is it on stock short blocks?
Old Apr 23, 2020 | 08:05 PM
RB04Av's Avatar
Too little ring end gap.
Pretty rare unless nitrous or a blower or some such is involved.
Old Apr 23, 2020 | 09:29 PM
wannafbody's Avatar
It's from too many sloppy builds.
Old Apr 24, 2020 | 09:22 AM
KCS's Avatar
KCS
Moderator
Not enough ring gap, and also detonation can do it too.
It’s common on SBE with power adders, especially nitrous. Not so much in NA applications.
Old Apr 24, 2020 | 10:05 AM
Ls7colorado's Avatar
Old Apr 24, 2020 | 10:32 AM
FCar2000TA's Avatar
Veteran: Air Force
Will 11.6:1 compression on a stock LS1 short block create enough additional heat to make stock ring gap an issue?
I am trying to decide if keeping my short block stock is going to be safe with 60cc MMS 220 heads. The cost of new rotating assembly + block machining + assembly is more than I was anticipating.
Old Apr 24, 2020 | 02:00 PM
thats really not that high of compression, a STOCK ls2 is 11:1
Old Apr 27, 2020 | 12:38 AM
Rickys2003svt.cobra's Avatar
Mine broke @ 90k. Stock ls1 on 9psi no water/meth or intercooler and an crappy tune
Old Apr 27, 2020 | 08:43 AM
RB04Av's Avatar
Probably not. That kind of heat doesn't come from compression. Stock motors aren't built so tight in that area anyway, to where they're THAT sensitive.
Ricky's is long-term detonation. That whole thing is just ate up with it. I think his crappy tune diagnosis is on the money.
