Coolant coming out of Exhaust Manifold Bolt
"Boosted" doesn't really make any difference.
Somebody either put in a bolt that was too long and busted through, or drilled too deep to Heli-Coil the hole, or something like that; and hit the water jacket. Not a big deal, not related in any way to "boost". As said, put some thread sealer on the bolt and put it back in, should be fine.
If you're the one that busted it out, maybe get a shorter bolt.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If you're the one that busted it out, maybe get a shorter bolt.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
You will REGRET changing the bolt size. That makes a big mess you have to fight for all eternity in ways that are hard to even imagine in the moment of lazying out.
Just heli-coil it back to the right size, put high-temp sealer on the bolt threads, and be done with it.
Moderator
Received 1,851 Likes
Update: ok well tried resizing that bolt like the others, but I didnt want to push it to far, so oem M8 is back on thank God its holding 18 ft lbs with red high temp rtv, letting it cure for 24hrs, then adding coolant in the am, Thanks for all your helps.
By the way I have 2 M9 bolts holding the headers real well, 2nd from far left and lowest one in the middle.
