how do I free up a "Stuck" Lifter
got a clicking.....
I Think Its a Stuck Lifter......
Just looking for the best ways to try to free it up...
all my mods are on my car page.....
and how the hell would that work on the lifters????
lifters are not in the cylinder...
do you even know how a pushrod engine works???
Dale
soon as I'm up past 2k it gets quiet until I get down below for a while..... like when I'm sitting at a light...after some highway driving....
Air to unstick a lifter?????? If the combustion force does not do what you say a compressor sure won't.
Check to make sure all is tight There is no adjustment to the lifters. The only way to find out is to inspect the parts. Crap in the oil only masks the problem if there is one. If you go in there make sure all of the lifter carriers (the plastic holders) are in good shape and that the alignment flats for the lifters are straight (90 degrees to the lifter). Some of them are off a little and could cause a problem at the lifter wheel and cam interface. It is the same lifter as the LT1 and has not been known to have problems.
Scaz
had several buddies of mine listen to it...including the local owner of a performance shop here in KC..and they all have years of motor experience...they also think lifter.....
hoping its just "stuck"
gona try some Auto Trans Fluid (DexronIII/Mercron)
bout an oil filter's worth...for about 150 miles.....see if that works... it an old schooler way to rule out stuck or colapsed
used to have an 8.05 1/4 mile 426 hemi-cuda.........
know plenty about motors...just usually blew them up before the lifter got "stuck" or "colapsed".....
Blow them up. I wouldn't admit to that.
I don't have to tell you what I have done. Pick up the National Dragster and find out for yourself.
Trans fluid is to unstick lifters in junkyard engines.
bye
If you have duals you could have a broken inner spring. You won't be able to see it just by looking at it you need to remove the springs to inspect them.
A stuck lifter is one of the rarest things that can happen in an LS1. Collapsed would be more probable with that 230 duration cam.
In anycase you have to at least remove the covers to inspect, and i would remove the rockers, p-rods to take a look at the lifters. with a good light beam. You could stick a thin pen magnet to catch the lifters and feel if they're free or if you catch any debris (like retainer ring)
You usually bend a pushrod when you break the inner spring because an end gets between the coils of the outer spring and causes a solid stack up.
Have you guys tried the Schubeck roller lifter. It only has .010 or .020 travel. They are made for racing. You need an adjustable valvetrain. They act like solids and do not pump up or collapse. You preload them very little. We run them to 7800 rpm with no problem.
Keep you eyes open for Jessel to come out with an aluminum lifter guide to replace those plastic things. Check out their rocker system too.
Kevin
