Reuse OEM lifters or new Summit brand
GM doesn’t make parts. They make vehicles. They buy parts from vendors, who make the parts for them. This “pandemic” has shut down manufacturing across the globe. The Summit lifters are GM spec, but there’s no telling who actually makes them. I found out long ago that Summit branded parts are quality. I’d run them in a rebuild for sure.
The following 3 users liked this post by Che70velle:
The following 2 users liked this post by Che70velle:
00pooterSS (05-28-2020), G Atsma (05-28-2020)
Summit said the GM strike and Covid is why they're out of lifters, you said GM doesn't make parts. Summit never shut down so they (vendor) have a buyer for the lifters.
Business 101? No, plant closure/employee absenteeism due to worldwide pandemic and stay at home orders.
Maybe don't try to prove me wrong when I said Summits supplier is either GM or the supplier for GM. Just let it go.
What?
What?
00pooterSS (05-29-2020), G Atsma (05-28-2020)
The following 2 users liked this post by wannafbody:
Look all of the LS7 type cast body lifters are made by either Eaton, Elgin, or S-Line or other manufacturer such as Delphi. That includes wether they are boxed as Lunatis, Howards, or Cranes, etc. All of these lifters are made with cast bodies and to a price point. And no Summit doesn't make lifters. The above lifters are LS7 style lifters nothing more, but also nothing less. The big improvement came a few years ago when the rollers were upgraded from swaged to line lock clips.
The earlier improvement from the 1987-2004 lifter is the reinforced body where the roller is encapcellated instead of open wheel.
The following users liked this post:
The following 2 users liked this post by RonSSNova:
00pooterSS (05-29-2020), G Atsma (05-29-2020)
The following 2 users liked this post by Ls7colorado:
#36
I would think that the LS7 is the reason LS7 lifters came out. (and then became the standard replacement-- save you from typing that)
Which brings up further controversy. Summits website says LS7 lifters have ceramic check *****.
https://help.summitracing.com/app/an...7-engine-specs
Now the question becomes: Whats the definition of an LS7 spec lifter? Because I know it's got nothing to do with ceramic anything. So everyone thats been saying LS7 lifters are just the ONLY replacement OE lifter for an LS engine are wrong.
Well according to Summit anyways.
Insert bullshit below.
Lifter Style Hydraulic roller (with ceramic check ball for high rpm operation)
G Atsma (05-30-2020)
#38
Finished the cam lifter swap and thought I would check back in to give an initial review on the Summit brand lifters. Keep in mind this is a mild Cam Motion Stage 2 truck cam, known to have a gentle lobe.
Anyway, first impressions are great. They pumped up immediately at startup and are very quiet. Time will tell as far as long term reliability. As of this moment, I am glad I used them.
Thanks
Thanks
The following 2 users liked this post by Jake Wade:
00pooterSS (06-01-2020), BigBlackCamaro (05-30-2020)
#39
Here goes- I've seen one other GM lifter that is way pricier than the fabled LS7 lifter. I think it is used in factory racing applications (NASCAR?)
I just looked on CamMotion's site where I saw them but they show no price now. Might also be out of them.
#40
That must be the Cadillac CTS-VR lifter you're talking about. Those also have a ceramic check ball, rated to 8500 rpm. Cost around $400, back ordered about everywhere.
