Tsp cam
TSP showed several tests with low lift vs high lift dyno overlays and the high lift (600) showed an increase in power at every point over low lift (550). They did it on stock 5.3 motors using their low and high lift truck cams in different durations, comparing all things equal except lift. In other words I agree with the theory but the testing showed otherwise.
you're still spending a larger portion of the camshaft duration at peak flow which improves power across the entire rev range.
Sizing the cam to not go above your peak flow numbers would be like setting your shift point at peak torque.
