Tsp cam
Old Jun 10, 2020 | 04:50 AM
hamood91's Avatar
Default Tsp cam
Hi guys,
anyone try this camshafts:
TSP Low Lift "MAX" Cathedral Camshaft.
228/228 .550/.550 110+5 LSA
On 5.3 engine
Old Jun 10, 2020 | 12:24 PM
00pooterSS's Avatar
Weird choice
What is the motor going in?
Manual or auto?
If it's an auto what stall are you using?
Old Jun 10, 2020 | 02:55 PM
hamood91's Avatar
Im just asking , because still thinking for which cam i will go for it after that i will check which convert will work with my setup .
her is my setup :
it LS swap to 72 chevy el camino with th350 and 3.73 rear end .
Old Jun 10, 2020 | 05:51 PM
00pooterSS's Avatar
That cam could work in that setup. Would want at least 3000 stall.
I'd go with a different cam though.
Old Jun 10, 2020 | 09:48 PM
wannafbody's Avatar
I'd do the .600 lift version
Old Jun 10, 2020 | 10:08 PM
grubinski's Avatar
That seems like a lot of cam for a 5.3 with an auto trans. What compression are you running?
Old Jun 10, 2020 | 11:15 PM
hamood91's Avatar
See i will be running stock head and will be stock compression , so i need choppy idle cam and sound like big block engine .,
i checked again the TSP and there is bfd chop monster cam (https://www.texas-speed.com/p-9015-t...edral-cam.aspx)
what do you think guys about this cam .
Old Jun 11, 2020 | 10:48 AM
Ls7colorado's Avatar
I wouldnt buy a cam that doesnt give the specs....
The first cam you listed will have a good chop to it
the summit 8704 cam would be a good cam if your only concern was "CHOP"
https://www.summitracing.com/parts/sum-8704
Im NOT recommending that cam, just saying it would do what you want lol so would a ton of other cams, but your gonna need a decent tuner to make them drive ok.
sounds like your more concerned with the way it sounds than how it performs?
Old Jun 11, 2020 | 11:24 AM
hamood91's Avatar
your right , i agree with you .
the problem there a lot of cam will chop and have decent power but which one will be best for the setup i have i should think about it .
Old Jun 11, 2020 | 11:53 AM
A tip for you- don't buy a cam for sound. Get the cam that gets your engine where you want it to be. The sound will take care of itself. Cam sound is about nothing but posing.
Old Jun 11, 2020 | 12:08 PM
Exactly
What rpm stall are you going to be using?
If you go with a higher stall... say 3500-4000 you can get away with a quite a bit of cam
just depends on what you want
Old Jun 11, 2020 | 12:31 PM
RonSSNova's Avatar
UhOh, Gary just came up with a new cam name.......
(Insert cam company here) proudly introduces our new line of Poser Cams.....
Old Jun 11, 2020 | 12:35 PM
hamood91's Avatar
probably i will be going with 3000-3500 stall
Old Jun 11, 2020 | 01:15 PM
carb or fuel injection?
Old Jun 11, 2020 | 01:51 PM
hamood91's Avatar
fuel injection with Holley terminator x ecu
Old Jun 11, 2020 | 02:22 PM
Summitracing's Avatar
LS1Tech Sponsor
Hey there, it sounds like you want some chop! As other have said, you can definitely ruin driveability if you run too big of a cam, but we have an option for you. Our stage 4 SUM-8714 Truck cam has a 41 degree intake closing point to maintain your torque in the mid-range. Where it gets the chop is from it's 5 degree BTDC intake opening point. This is a reasonable number and not too hard to tune around. Next up is the exhaust opening point which is a little later than our automotive cams to boost low end torque. Lastly we've set the exhaust closing at -1 degree so we net 4 degrees of overlap. The cam has .545 lift and works with inexpensive LS6 valve springs. This cam would like a 3000 stall, but you could run a little less than that if you don't mind that "getting up on the cam" feel.
__________________
800-230-3030
www.SummitRacing.com
Old Jun 11, 2020 | 03:09 PM
hamood91's Avatar
okay it lock nice cam and will have good mid power gain . what do you prefer for my setup? leave the chop ideal aside
Old Jun 11, 2020 | 04:44 PM
00pooterSS's Avatar
Since it's going in a car... well el camino call it what you want lol, with a 3000-3500 stall i'd pick a cam in the low to mid 220's intake, around 230 duration, around 600 lift and close to 112 LSA. There's a million cams out there so it's hard to narrow down just one for you.
The cam summit posted should work well, the guy that posts here knows far more than me about specific valve events so if he recommends a cam, I'd feel very comfortable with the recommendation.
Old Jun 12, 2020 | 01:44 PM
AwesomeAuto's Avatar
Picking a cam just for sound only works well for boost lol.
They can have some pretty bad N/A results. The Thumpr cam line is definitely not known for power.
I'd go with something that has a bit higher lift.
Old Jun 12, 2020 | 02:15 PM
Bspeck82's Avatar
Stock heads will work great with a .550 lift cam. You wont likely flow much more to .600 and your spending more energy pushing the valve down and not gaining any power which can actually reduce power and worst case make air turbulent. Chop is a product of valve overlap . More overlap more chop. Most people like to compare overlap at .050 lift to determine potential driveability, character and chop. To figure this out you take the .050 numbers ((intake+exhaust) / (2)) - (2(LSA)). Your tuner can also play with the sound a bit. As do some other things like valve size. Anyways, most performance cams will have a nice chop to them and too much chop is too much overlap and it will sound nasty but run like a dog. In short, everyone will make fun of you and its lame. I'd find a cam that offers the best gains in the RPM range of your overall combo and it will sound how it sounds. Wont sound stock for sure. A larger case magnaflow style muffler will help create that big block sound too.
