Max effort must haves
Old Jul 1, 2020 | 11:10 PM
wannafbody's Avatar
9 inch or S60 in place of the POS 10 bolt
Old Jul 2, 2020 | 12:27 AM
vw1320's Avatar
Originally Posted by sxc Z28
freeing power is more important than adding power. Probably worth 5-10rw all said and done but rev much better
I don't disagree at all. I can however tell you that on a different platform the difference between turning the power steering pump and bypassing it with a shorter belt was exactly 0 hp through the entire pull. Granted with the wheels straight on the dyno that isn't shocking but its not exactly like you are turning the steering wheel that much going down track - at least you shouldn't be I figured it would see at least a little gain - at least at high rpm but literally none. Can't see how a tensioner takes more power to spin than a power steering pump.
Old Jul 2, 2020 | 10:07 AM
sxc Z28's Avatar
My bolt on ls1 car is very consistent. Best et was 11.60@116.4 with my version of a short belt(crank, alt, power steering, tensioner, back to crank). I ran that at +400da. I also went 11.62@116.7 a different day with only change being a 4 rib belt going crank to alt. Identical 60’ but +1500da. That’s the data I have to go off of.
Old Jul 2, 2020 | 04:28 PM
vw1320's Avatar
Hard to say but the change in da would say it was worth something. Thanks for sharing.
Old Jul 2, 2020 | 05:52 PM
HioSSilver's Avatar
It's usually not the little bit that matters. It's the sum of the little bits.
I would look at the aero of that brick nova too.
And weight weight weight.
Old Jul 2, 2020 | 07:01 PM
Darth_V8r's Avatar
Moderator
Weight more of a bolt OFF
Old Jul 2, 2020 | 09:20 PM
Cwarta's Avatar
The 8.5 ten bolts are actually pretty robust. But it’s got a 8.8/9” hybrid
Old Jul 3, 2020 | 07:11 AM
HioSSilver's Avatar
nah....more than one way to get rid of weight.
