High Compression Discussion
Old Jun 30, 2020 | 12:54 PM
ASRoff's Avatar
Originally Posted by Labsforever
most dome pistons are a solid dome so they end up heavy. Approximately half of that extra weight can be milled off the underside in a na engine. Piston dish volume is limited to an extent by the compression height needed so we are back to a compromise between the two in my book
perhaps some custom CNC work in a cross hatch pattern on the underside of the dome to retain cooling oil and pull some weight may be in order... even some easy dimpling may help here.
Old Jul 4, 2020 | 10:23 AM
64post's Avatar
What I tried to do on mine was preserve as much of the chamber as possible. Ended up with a net 1.3cc dome (AFTER valve reliefs figured in), so it's like a little flat "mesa" on top of the piston. but that got me 12.7. Not 14. And it did make the pistons heavier. I noticed that while shopping. I could get dished pistons in the 450g range all day long, but domes were in the 490-500g range all day long.
Then heftier pistons require beefier rods, and it spirals.
What I have in my head for a future build is sort of like this. Another big bore motor. Stroke as yet undetermined. Something based off the LSR casting, starting at 52cc and then running a 5cc dish to get compression into the 14-15 range. Seems like the best way to do it. Or even more extreme, a C5R bare casting in the right hands with a 30cc chamber, no milling, but then needing a 20cc dish to get into the 16:1 range.
But it's diminishing returns, and boost becomes much easier, so I see your point for sure.
Yes, I know what you mean about weights of pistons with domes, I looked high and low for a lighter piston for this LS3 build I finishing up now. I ended up using a Mahle 2cc dome piston that weighs a whopping 492 grams but I’m chasing high 11.5 ish compression and it’s not that easy to do with a flat top with stock stroke, it would require a tiny combustion chamber. My other alternate route and I don’t know why I didn’t go this way was to use a 6.300 626 gram rod and a JE 418gram 3cc dome 416 piston, bob weights might have been in the high 1600’s. With a 3cc dome 11.75 static would be easy with a barely milled LS3 head. As it turns out I’ll have 11.5-11.65 with 65-66cc head and still have mid-high 1700’s bob weights using 610 gram rod.
