Cam pin location question
Remember, this is a 4-stroke engine. The crank turns TWICE for each complete engine cycle, the cam turns ONCE.
When the crank dot is at 12:00 and the cam dot is at 6:00, you're at THE OTHER instance of #1 TDC besides firing. At that point, the #1 exh stoke is ending (#1 exh just closing) and the int stroke beginning (int valve just beginning to open). It's also #6 firing.
Turn the crank exactly 1 full turn; the cam will turn ½ turn; at that point both dots will be at 12:00, the engine will be at #1 firing, and #6 will be at the stage described above.
The reason we build em dot-to-dot is because it's easier to see and not mess it up.
If so then the cam and crank dots should be as stated above and the pin on the cam at the 1:30-2:00 position.
