Rod/piston length questions
Old Jun 29, 2020 | 08:10 PM
Utinator's Avatar
Question Rod/piston length questions
If the info I found is correct, then the stock rods are 6.098". A lot of aftermarket rods are 6.125". If you replace the stock rods with longer rods, will that increase compression? The displacement doesn't change, nor does the stroke. The longer rod will change where the stroke occurs within the cylinder, though. It would seem that the compression would increase, due to the piston coming up higher, and possibly going above the deck. I'm guessing that is why they make pistons specifically for 6.125" rods.
Another scenario to discuss:
Let's say you have a 6.098" rod, and a piston made for a 6.125" rod. Would that lower compression? Would this pull the piston close enough to the bottom to cause it to rock at BDC?
These are all things I think that I need to understand before contemplating any future builds. I have read threads about the advantages of the longer rods. I just didn't see anything about how the longer rods affect things like compression, PTV, and other clearances. I have seen pistons advertised as 6.125" rod pistons. I just don't know what is different about them. Any insight is appreciated.
Old Jun 29, 2020 | 10:05 PM
01CamaroSSTx's Avatar
Deck height of an LS block is 9.24 inches and when setting up a rod piston combination for a given crank you apply a formula
Stroke divided by two plus the rod length and compression height of the piston. Example: 3.622/2=1.811+6.098+1.33=9.240 (Stock)
Now throw in the 4.00 stroke crank and now you have 4.000/2=2.000+6.125+1.115=9.240 (Stroker)
Old Jun 30, 2020 | 07:18 PM
Utinator's Avatar
I'm not talking about changing the stroke. I'm just talking about changing the rods and/or pistons in a stock engine.
Old Jul 1, 2020 | 11:29 AM
KCS's Avatar
KCS
Moderator
It probably won’t increase much because you still have to have clearance between the piston and head. Shorter rods, with all else equal, will lower compression. You can play with the online calculators and change where the pistons comes out of the hole to in the hole to see what happens.
Old Jul 1, 2020 | 05:35 PM
Utinator's Avatar
I've been playing with this calculator: https://www.rbracing-rsr.com/compstaticcalc.html
The only way I see to account for a rod length change, would be in the "Deck Height" box. Assuming you go from a stock (6.098") to an aftermarket rod (6.125"), it should increase the deck height by .027". If it works this way, then a longer rod would increase compression (all else equal). Does this sound correct, or am I way off base here?
Here's my rational for doing this:
If I want to swap the stock rods and pistons with a forged set, how do I maintain the same or close to the same compression? There are no forged, 0cc, Flat-top pistons on the market for an LS1. The closest I could find are the Summit +3cc mini domes, and some -5cc flat tops with valve reliefs. I'm currently at 10.23:1 compression with stock rods/pistons (0cc flat tops).
Option 1: -5cc pistons (made for 6.098" rod)
These 5cc valve reliefs would decimate my compression (9.67:1) with a stock-length rod. A longer rod would help compression (10.27:1) with these -5cc pistons (made for 6.098" rod). The longer rod should increase compression with these pistons. I am hoping that it works this way.
Option 2: +3 cc mini dome (made for a 6.125" rod)
These +3cc mini domes might be ok with a 6.125" rod (10.61:1 compression). If my end goal is to add boost, then I'd rather keep the compression down. These pistons (made for a 6.125" rod) with a stock length rod should lower the compression to 9.97:1.
So, which option would be better? Are either of these options actually practical?
Old Jul 1, 2020 | 05:42 PM
Utinator's Avatar
So you can follow along with the calculator, here's my current set-up:
Bore: 3.898
Stroke: 3.622
Head Gasket: .052
Deck Height: 0
Piston volume: 0
Chambers: 66.5
NOTE: My 317 heads have been milled about .030" to achieve the 66.5cc. I don't know the current PTV clearance, but it is something to consider.
Old Jul 1, 2020 | 07:09 PM
wannafbody's Avatar
Simply swapping to the aftermarket rod with a stock piston should increase stroke slightly and increase cubic inches slightly.
Old Jul 1, 2020 | 07:42 PM
And most likely make contact with cylinder head should you try to put a piston designed for 6.098 rod onto a 6.125 rod.
Old Jul 1, 2020 | 08:18 PM
wannafbody's Avatar
Yeah, I'm not sure about how much piston to head clearance these engines have.
Old Jul 1, 2020 | 09:47 PM
KCS's Avatar
KCS
Moderator
How do you figure?
Old Jul 1, 2020 | 09:55 PM
RonSSNova's Avatar
The pin sizes are different anyway.
Aftermarket 6.125 rods have .927” pins.
Stock are .945”
Old Jul 1, 2020 | 10:41 PM
Point taken...LOL
Damn why didn't I think of that!
Old Jul 2, 2020 | 12:47 AM
The ONLY thing that increases the stroke is a longer throw on the crank. A longer rod does not increase the stroke.
Unless of course you were joking.....
Old Jul 2, 2020 | 04:10 PM
Utinator's Avatar
Stock are .945”
Well, there goes that idea.
