rockers on tfs 225
Some will say 620-630 max lift while on trunion upgraded rockers for a Daily, while some will run higher lift and high rpm on a Dragstrip Only due to rocker arm weight factor.
I'm sure others will present other variables as well...
So I asked him about the guide material. He said the guides are made by CHE and are very hard. He didn’t see an issue with using stock rockers.
AFR actually suggests a trunion kit if using stock rockers. Interesting. Or of course rollers.
I’m using different lifters on this 6.2 so I did the PR length check with both the rollers as well as stock rockers.
Also having a hard time deciding what I want to do. I sure like the simplicity and lower noise of the stock setup.
