*Cam opinion's and advice*
Old Jul 15, 2020 | 10:46 AM
  #41
Bspeck82's Avatar
Originally Posted by SLP IROC-Z
I drive a 233/241 on 112.5 with tfs 220 as casts and the drivability is great, just need to know how to tune it to get there and its a 6 speed. The power is unreal, car went 10.84 @ 125 with the stock ls6 topend and now it would embarrass that setup. Do6nt believe everything you read on the internet.
"driveability" means something different to everyone
Old Jul 15, 2020 | 11:31 AM
  #42
SLP IROC-Z's Avatar
When the "drivability" is like stock how can you complain. Just like the rest of the "big" cam ls1s ive tuned they end up driving like stock. Said it before and ill say it again its all in the tuning. That is fact based not i read it on the internet so it must be true jargon.
Old Jul 15, 2020 | 11:34 AM
  #43
Bspeck82's Avatar
Ok, not sure how much of the big cam syndrome you could tune out especially on our garbage PCMs, but that still doesnt mean this guys application warrants a big cam. A mid 220s cam is perfect for a weekend street car.
Old Jul 15, 2020 | 11:58 AM
  #44
00pooterSS's Avatar
Originally Posted by madmike9396
Thanks for the advice. I've seen first hand what over cammed cars run like. Got they *** busted by a smaller cam car and everyone was shocked 😂
Thanks again
I agree and that's also where the total package comes into play (heads intake exh stall etc). Cam for what you got, not the highest hp number the cam itself can make.
My 2000 SS was not fast by any means, it was a bolt on only car, but it beat more cammed LS1 cars than it lost to, due to that I like to look at what most consider a medium sized cam. My car was full weight plus, heavy street wheels front and rear, bolt ons and and ran 1.6 60's and 7.6 in the 1/8th.
There were really well done cam cars that would run 7.3-4 or so in similar trim, faster if lighter. But plenty of bolt on and cammed cars that ran closer to 8.0 because they were over cammed and the total package was crap. In short, the cam alone is far from the answer and there's so many other areas to look at. I really don't think if you chose a 227 intake duration or a 232 that it will make or break your setup. But I do think the 227 will be a little more crispy since it will keep DCR up a little higher (speaking generally here yes I know this can be custom tailored, but I'm talking about these out of the box cams were are looking at in this thread), and peak tq closer to your stall speed and hit the converter a little bit harder. I am no means a guru here, just my opinion.
Old Jul 15, 2020 | 02:19 PM
  #45
madmike9396's Avatar
As you can see in my signature my last car wasn't anything special but it moved out for what it was. It would of ran better with a Yank converter and some more gear. The best I could get it to 60' was 1.56 with a FTI hard hit 4k. Zzracer done the ported 799s and it had a fast 92 setup and F14 standard lift cam.
Old Jul 15, 2020 | 02:46 PM
  #46
00pooterSS's Avatar
Man 1.5x and 7.1-7.2's is moving out pretty good for a stock cube stock weight F body car. It doesn't get much better than that until you shed weight IMO.
Was that on street wheels or a drag setup?
And yeah the 3.42's probably weren't helping, unless you were crossing the beams at the top of second and avoiding the 3rd gear shift happening right before you cross. Then maybe they were. 7.1 is about as good as it gets for a cam head intake F body that I'm familiar with at stock weight. I'm not sure how much faster you'd be if you geared it since there would be another shift in there
Old Jul 15, 2020 | 02:55 PM
  #47
I had weld rts 15s with a bias ply in the rear. Also tried the stock 17 10 spoke wheels with ET streets. Would 60 identical.
it was actually bored 20 over and 3450 was race weight
Old Jul 15, 2020 | 07:57 PM
  #48
zzracer's Avatar
Would have been 7.0 -6.90 car with a converter like mine. That Fti was too tight! A 102 intake wouldn't have hurt it either.
Old Jul 16, 2020 | 09:32 AM
  #49
True.....
Old Jul 16, 2020 | 10:55 AM
  #50
wannafbody's Avatar
This thread reminds me of Mavn. He did the Summit racing Stage 1 Ghost Cam which is really mild. He said that when he upgraded to the stage 2 cam (which is fairly mild) he got slower.
Old Jul 16, 2020 | 11:52 AM
  #51
That's exactly what I want to avoid
Old Jul 16, 2020 | 01:51 PM
  #52
00pooterSS's Avatar
What converter is that?
Old Jul 16, 2020 | 01:57 PM
  #53
Lineman74's Avatar
Stage 3 Polluter Cam is a good choice IMO.
Old Jul 16, 2020 | 04:19 PM
  #54
PT4000 Yank
Old Jul 16, 2020 | 05:08 PM
  #55
00pooterSS's Avatar
PT4000 Yank
Does that PT4000 hit harder than the 4k you have listed in your sig? He said it would have helped your car go faster, curious as to why
Old Jul 16, 2020 | 06:08 PM
  #56
I want to say his old car with similar power, 300lbs heavier would cut 1.4x 60' with the Yank stall.
PT4000 is strictly for NA cars
I want to say his current setup does 1.3x 60' but its about 500hp to the tire NA Ls2.
Old Jul 17, 2020 | 01:37 PM
  #57
zzracer's Avatar
My best 60 to date is a 1.409 in good weather. I recently installed rear coilovers and went 1.41 in the heat. It should do 1.3? Now in good weather. The pt4000 is a looser converter which flashing higher than the converter he had .
Old Jul 17, 2020 | 01:46 PM
  #58
98CayenneT/A's Avatar
I second this
Old Jul 17, 2020 | 03:40 PM
  #59
zzracer's Avatar
Originally Posted by 98CayenneT/A
I second this
His car would be a turd with that cam unless he bumps compression.
