How many ways to stroke a motor?
Think of how an engine operates, and you will wonder, as I did, how or why you could even ask such a question. SMH....
Technically, yes you can stroke the motor with the stock crank by doing off set grinding the stock crank. It was fairly popular back in 1999-2001 due to the high $4000 coat of stroker crank kits.
With an offset ground LS crank the stroke can be increased to about 3.825 from 3.62 stroke. However special bearings are required and getting a set of honda bearing sized (or other) small block chevy rods can end up being expensive. Usually enough so that just getting an aftermarket LS stroker crank is the smarter option. Sometimes used NASCAR rods with the right bearing size show up and can make the off set grind almost tempting.
However, with the machine work costing $250 to $350 to properly off grind and reheat treat the stock crank etc one could sell the old stock stroke crank for $150 to $250 and be $400 to $600 towards a new aftermarket 4 inch crank that will make more cubes! Plus no worries about finding special custom parts sometimes expensive to finish the project.
I researched the option in detail back in 2003-2004 when I had access to a set of inexpensive Honda bearing small block chevy rods. However the price of stroker cranks came down. I decided $1,000 aftermarket Callies crank was a more cost for the cube effective choice way back then. The logical argument for the aftermarket crank is even greater today unless you can get the special rods for free. Even then the aftermarket crank is better due to cubes
BTW - if you want to do an offset grind, PM me I might be able to find the contact info for a good crank shop. I revisited the offset idea back in 2016 to 2018.
Also GM offers a new 3.85 or 3.86 stroke crank in the 6.6 liter L8T engine Gen V engine. I don't know if it will work in an earlier Gen 3/4 block. It costs about $595 if you shop around.
Your buddy must be really dense where it comes to engine knowledge. Have him read some books, IF he can...
We all started learning somewhere and LS1Tech is a good place to start. I think we should be nice and polite to folks that come to LS1Tech to ask legitimate engine questions.
When I think of some of the first questions I asked 35 years ago about engines - I'm grateful folks took time to answer and explain.
Seems like a good tradition to continue
It is one of the most basic principles of engine operation.
I hope he learns a bit more soon. Sounds like you could be of help there.
Happy hotrodding!
Happy hotrodding!
