Why do people do 383 Stoker LS1
Totally ignores the huge factor of elevation. 70 degree day in Denver with zero humidity still has worse air than a 100 degree day in Florida with 99 percent humidity. Lol Humidity sucks but run a mile in Florida then run a mile in Denver and your lungs are going to hate Denver lol.
Not exactly true...ask national level racers that run all over the country where they would rather run...Denver or (Florida, Georgia, miss, etc). The temp doesn’t have to be similar at all for the air density to still be much better in Florida than it is in Denver. It could be 30 degrees hotter in Florida and you would still have denser/better air than Denver. Take your car to Denver and you are going to make less boost due to air density and make a ton less power. It seems so obvious and proven I can’t even understand how anyone would argue this.
383 LS1 can be nothing to sneeze at, but I think its just a lot of folks really prefer what the larger 4.0-4.060+ bores are capable of. That small 3.9 bore is a choker in comparison. Its too bad the LS1 can't be bored .040" or .060" over.
I'll bite on that one all day. The only ones saying boost is boring are either A) The ones who've never done a boost build, or B) The ones who failed at doing a boost build or didn't finish it.
I do agree though, having a better behaving street mannered car that makes more power, WAY more torque, and typically ends up cheaper in the long run can be boring
about Boost vs NA?Talk cam specs and have a real show
What's the best 3/4 race cam for my LS swapped Buggati Veyron Super Sport?
Sorry to pipe on but it's not about own power. Under the curve with a 383 is more fun and faster, without question.
The 6.0 is popular because it's done. Check the junk yard block and go from there if all is well.
It makes more power EVERYWHERE vs a 346 with like components. It also eats a larger cam and make sit easier to drive. Lots of reasons to go for a 383 over a 346 but the 346 is no slouch.
could you imagine the hate someone would get from LS swapping a Bugatti?! It would be epic.
