Which brand Barbell should i get?
Old Sep 6, 2020 | 05:36 AM
TURBOPOWERED68's Avatar
Default Which brand Barbell should i get?
Did some research and came up with a few of the big names in the LS world have them, Which one should i get?
Thanks for your help.
Old Sep 6, 2020 | 08:17 AM
I’ve put more SacCity billet barbells in than I care to count with zero problems. Excellent product and even better customer service.
Old Sep 6, 2020 | 12:57 PM
Ordered
thanks
Old Sep 6, 2020 | 01:19 PM
Z28SteveA4's Avatar
I just received my billet barbell a couple weeks ago for my build and it’s an awesome piece!!
Old Sep 6, 2020 | 01:31 PM
64post's Avatar
Lots of offshore knock offs on those billet oil diverters on eBay. You’d think the Sac City people would have a copy infringement suit going.
Old Sep 7, 2020 | 09:33 PM
I agree, but it might be hard to pursue with many of them coming from China. You'll be chasing the wind....
Old Sep 8, 2020 | 10:30 AM
64post's Avatar
The customs people don’t have to let them in. eBay doesn’t have to let people sell them, there’s protection available. You can’t sell copycat watches on eBay, just sayin.
Old Sep 8, 2020 | 11:08 AM
R6cowboy's Avatar
Buy SacCity billet barbells and nothing else. Do not skimp on an already inexpensive devise that directs oil flow in your engine and buy a cheap knock-off.
Old Sep 8, 2020 | 12:02 PM
You make good points! But I'm not sure customs will be suspicious of some aluminum machined parts UNLESS given a heads up. And maybe that IS happening.
Old Sep 8, 2020 | 04:24 PM
Kfxguy's Avatar
Saccity corvette ftw.
Old Sep 8, 2020 | 07:42 PM
Buffalony's Avatar
Improved racing has a double o-ring barbell. Any thoughts on that one?
Old Sep 9, 2020 | 09:18 PM
ASRoff's Avatar
saccity here as well.
Old Sep 9, 2020 | 09:27 PM
Rich-L79's Avatar
I read somewhere, on a Corvette site somewhere I think, that the o-ring could very likely get cut on the sharp edges inside the galleys the barbell needs to pass through to get seated. It kind of makes sense, if the o-ring is big enough to fit snugly, it is going to catch on any sharp edge inside. A tight machined fit seems like a better idea.
Old Sep 10, 2020 | 08:14 AM
ImprovedRacing's Avatar
LS1Tech Sponsor
It was tricky to get it just right, but we designed it with just enough squeeze to create a seal with no gap without cutting or damaging the O-ring during installation. If it's coated with oil before installation and inserted carefully, it's not a problem. It creates a much better seal than no O-ring, even though it's not designed with as much squeeze as a typical static radial O-ring seal, like the rear O-ring on the barbell. The pressure drop across the tip of that barbell is not very significant, so the O-ring doesn't need to be very tight.
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
