Looking for compression answers
Old Sep 10, 2020 | 02:01 PM
RamLS1500's Avatar
Default Looking for compression answers
Im needing some on trying to figure out what my compression ratio will be on my current motor build
gen 3 5.3
4.8 flat tops
milled 706 .35
stock head gaskets
stock rods
Any help at all would be very helpful
Old Sep 10, 2020 | 02:15 PM
About 11.3:1. I used Summit's compression calculator.
Old Sep 10, 2020 | 03:28 PM
RamLS1500's Avatar
thank you sir !!!! Should be a snappy motor haha
Old Sep 10, 2020 | 05:23 PM
00pooterSS's Avatar
Using
3.78 bore
3.622 stroke
57 cc heads
0 dome volume (no dome dish or valve reliefs)
-0.005 deck height (0.005 pistons above deck)
.052 head gasket thickness
I come up with 11.1:1
Using 56cc head, and is actually my guess as to where you're at, which G probably did too, I come up with 11.3:1
If you go to a .045 headgasket (ws6store) it would be 11.51:1 with 56 cc
And I like the idea of a .045 gasket
Make sure you measure valve clearance, .035 is quite a bit off the head.
