2002 Formula HCI Discussion
Old Sep 29, 2020 | 05:32 AM
  #41
mstansbury0704's Avatar
Originally Posted by betrezra
No worries. I’m not running around town telling people I have a 484 hp ls.
its just a dyno run at that shop on that day
i can say it transformed to power band everywhere
No doubt, I was just asking lol. Hell, us little 5.7 LS guys gotta stick together these days
I Need a fast pretty bad, I want the 102 but for all of the extra add on crap and getting it to fit idk whether it would be worth it. Also how do you like the tsp RRs? I’m running their new stock style ones with the bushing
Old Sep 29, 2020 | 05:37 AM
  #42
betrezra's Avatar
Default Rr
I still have the hs rr’s.
the tsp rr’s have not arrived yet.
next steps for this car is wgt reduction... coil overs sticky tires and some road course fun
hoping I can play w some gt3’s at this power level
Old Sep 29, 2020 | 05:43 AM
  #43
FWIW I run stock stock rockers on .630 lift lol. Don’t see any tip wear from them. but I’d like to throw some rollers on there next time i have them off. The tsp ones are the only ones I’d consider. For sure a good tire makes or breaks the whole setup
Old Sep 29, 2020 | 08:50 AM
  #44
Bspeck82's Avatar
I do the same, that's not whynew dont recommend then for him, he had cylinder heads with bronze guides that the manufacturer states should not be paired with stock scrub pad rockers. Although Texas speed for example, claims that with theirs you can run stock rockers.
Old Sep 29, 2020 | 10:46 AM
  #45
I wonder why that is? The slightly reduced valve angle maybe induces Less pushing on the valve guides??
Old Sep 29, 2020 | 11:05 AM
  #46
Does TSP use bronze guides or iron? That is the difference.
Old Sep 29, 2020 | 11:15 AM
  #47
ah you’re right I overlooked that. I think TSP uses PM as standard. stupid me lol. I figured it was something else as I think you have an option between PM and Bronze. Per my head build receipt I got these: 143-30-8674U - Qual Cast Steel Guide for Aftermarket LSx Head Castings: .502 OD..
Old Sep 29, 2020 | 01:18 PM
  #48
Bspeck82's Avatar
They use a bronze guide. The guide is manufactured by I believe CHE, dont quote me on that, but they told me it is much more durable compared to the competitors bronze guides and they are comfortable with stock rockers .630 lift.
Old Sep 29, 2020 | 02:04 PM
  #49
RedXray's Avatar
Correct CHE.
I'm running PRC 225 heads, stock rockers with smith bros bronze trunnions, .629/.615" lift with no issues. I only have a couple thousand miles since the head swap though... more miles will tell how the guides hold up.
Old Sep 29, 2020 | 02:19 PM
  #50
Bronze is an alloy of copper and tin, tin being the harder of the two.
I'm betting CHE's guides use a mix with more tin than that which the other guides use.
