Should I do a 408 or 454?
I've seen aluminum 402/408 LS2 short blocks for for $4,500 if you have a good LS2 block. Otherwise add cost if a block.
I've seen aluminum sleeved 454's for $7,500 which included a Gen IV block.
So between $2,000 to $3,000 difference depending.
While I'm a NA fan fir the coat the LSA Supercharger on the current 6.0 would be hard to beat hp per dollar. Given the weight of the typical full size truck, I'd want forced induction.
But yea, really depends on how far up the power band he would even be pushing it. I've been working with a friend on a non-LS based build of a 408. He stressed low-end torque, not expecting to exceed 5500rpm and 87 octane. We're using AFR 195cc heads. Should peak around 525ft-lbs at ~4k and over 475hp flywheel with the chosen valvetrain components (custom spec-cam). The torque curve will be amazingly flat from 3000rpm to 5500rpm (should make as much as 450ft-lbs @ only 2500rpm) and it will still pull to 6k (hp will be virtually flat from 5500-6k).
