Engine assembly but Piston hits valve... help
Old Oct 21, 2020 | 04:36 PM
Urocmyiroc's Avatar
Originally Posted by 00pooterSS
I think it's time to bolt down a head with a used gaskets and the lifters as they should be (not converted to solid) and measure preload and valve clearance and see where you're at. And what you need.
I gonna take a wild guess and guess that you're valve clearance will be fine and that you'll be around .080 preload with the 7.225's. But you'll have to measure to see.
The preload wont actually change your valve clearance, in and by itself, but the squish that comes from running them will actually reduce your lift a little and increase valve clearance a little. But very little and should never be considered a safety margin because there may be times the lifters don't deflect any of the lift.
Ok... I guess I want to squeeze every little bit out of it. But of course I want the safety too.
let me soak the lifters and do as you said.
I’ll get back to you guys.
as always, thank you for the help.
Old Oct 21, 2020 | 04:42 PM
00pooterSS's Avatar
Essentially what I was saying before is hydraulic lifters don't always maintain 100% of the cams lift, they yes can give you more valve clearance if they don't maintain the lift, but you should measure as if they did.
To do this with a solid lifter you need a pushrod or checker set at zero lash with the solid lifter, you did that buy you added preload of .070 which opened the valve .070 while on the base circle of the cam, which increased lift at all points by .070
Old Oct 21, 2020 | 04:48 PM
Urocmyiroc's Avatar
I understand, makes perfect sense.
I kind of sold myself on the roller to rockers and this was the first time I did that... wonder if it was really worth all the effort and money. I guess time will tell.
thanks again for walking me through this guys. Much appreciated.
Old Oct 21, 2020 | 05:03 PM
00pooterSS's Avatar
Every build is worth extra effort, it always comes out at the end and you're always happy you did it. Don't sweat it, keep at it.
Old Oct 21, 2020 | 05:10 PM
00pooterSS's Avatar
I should say bolting down the rockers and setting the rocker to zero lash with your solid lifter and using the length checker is best for checking the valve clearance, but with a light spring like darth said.
Or technically you could use no valve spring. Extra precaution would be needed there but technically that could be done but would likely be a pain in the ***.
If nothing else grab a spring from something and make it work as a light (soft) valve spring. Like a carburetor spring or throttle/brake pedal return spring.
Many ways to do this man.
Old Oct 21, 2020 | 08:15 PM
Check springs at Summit...I keep these in the toolbox. You’ll use them more than you think...
https://www.summitracing.com/parts/crn-99881-2
Old Oct 21, 2020 | 09:39 PM
Darth_V8r's Avatar
Moderator
Originally Posted by Urocmyiroc
I do want to know how the preload on these solid lifters is going to work out when I install the hydraulic lifters... does it mean I’ll have more than the PTV I’m showing now?
If so, is a thinner gasket advisable?
or should I opt for the next size up (7.230) on the pushrods since I needed 7.226 and I went with the 7.225 Due to it being closer in value.
Ok. Preload is for hydraulic lifters. When checking with a solid lifter DO NOT add preload. All that does is lift the valve.
That said if you have 070 clearance with an overly long pushrod on a solid lifter you will have about two miles of clearance when you install the hydraulics - which you should have with that cam. You should have plenty.
Old Oct 21, 2020 | 09:54 PM
Urocmyiroc's Avatar
I just ordered a set. I’m sure I’ll use them down the road.
Are you saying that I should use a thinner gasket? lol
I’m going to install the The LS7 lifters That I got for this build along with these new pushrods tomorrow and do a clay measuring. Glad I don’t have to fly cut the pistons. I’ll get back to you guys tomorrow.
Thanks to everybody that helped me along.
Old Oct 22, 2020 | 07:24 AM
Darth_V8r's Avatar
Moderator
I just ordered a set. I’m sure I’ll use them down the road.Are you saying that I should use a thinner gasket? lol
Order your hg based on deck height period. Stock bottom end pistons stick out .006. Order hg at .041 or .042 thick. Gives you the ability to push the most timing.
And you do not need to redo the clay with hydraulics. Just install, get your 7.2xx pushrods, and send it.
Old Oct 22, 2020 | 10:55 AM
00pooterSS's Avatar
A lower cost/good option on headgaskets is the ws6store .045 gaskets if budget is a concern
Old Oct 26, 2020 | 01:59 AM
Urocmyiroc's Avatar
Hello guys,
I have a .041 Cometic gasket and a .051 GM OE gasket to use. How much power would I leave on the table using the larger gasket. I’m asking because I like the GM stuff better Because it looks higher quality.
Old Oct 26, 2020 | 07:28 AM
  #32
Darth_V8r's Avatar
Moderator
It's not so cut and dry as "thinner HG is worth exactly 284.73628 hp". and obviously, that's not how much it's worth. It's about timing and detonation. Thinner HG allows you run more timing, tolerate higher compression without detonation. That kind of thing. It's better for your engine. Are you going to gain 1.3 seconds at the track from it? no.
Old Oct 26, 2020 | 12:16 PM
  #33
68Formula's Avatar
And to add to Darth's excellent comments...sometimes (with tight quench) it it can even result in more power but with less required MBT timing; giving you more safety margin between peak power versus detonation limit. Depends on how close you are to detonation limit for the octane being used to begin with.
