Cam recomendations
Could i just have a bigger intake valve installed and leave the exhaust valve stock since its the same size as ls1 head?
Anyone ever do this with the 706 heads with the small intake valve and how much would it cost?
10.5:1 243/799*
10.9:1 706/862*
*stock .051 gasket 3.905 dia
as we know with the lq9 10.1:1 vs lq4 9.4:1 otherwise identical gm claimed 15hp from 7 tenths in compression thats about 2hp per tenth. So theoretically if both the 706/862 flowed as well as a 243/799 youre looking at around 10hp difference from the compression.
My opinion is ptv is going to be very tight with stock heads and the cams youre looking at. You really need 11.5 compression with those cams but won't be able to run a thinner headgasket or mill the heads to get there. At 10.5 stock 243s or 10.9 stock 706s, the car will be faster down the track with 243s. But if you dump all the money into the 706s and see if they can recess the valves without killing flow so you can mill them to 59.5cc and run an .040 or .045 headgasket for 11.5 the 706 will be faster. Question to ask any ls porter is which head can flow the best ported and which head will be able to get 59.5cc chamber volume without reducing ptv.
We do offer our Single Plane cams. Those have tighter LSA's if that's something you're after. Keep in mind these were designed around applications with short runner intakes and open exhaust systems. They aren't the easiest to tune.
Feel free to use our cam timing calculator to compare IVO events of different cams. The IVO event Is basically idle quality. The earlier you open the intake, the more air you're taking in on the downstroke (at the expense of idle vacuum).
This gives some food for thought. Let us know if we could be of any more assistance. We'll be happy to help!
picked up a tsp tsunami v2 so that's the cam im going to run. I've decided to get prc stage 2.5 ls6 heads but wasn't sure if I could get 58cc combustion chamber and still have enough ptv clearance?.
I would like to achieve the most compression possible.
