Enginetech pistons for 6.0L
Old Nov 19, 2020 | 11:06 PM
mattt's Avatar
That's a bummer to hear someone say not a Silv-o-lite casting but it is what it is.
I'm in Anaheim. How about you?
Old Nov 19, 2020 | 11:08 PM
mattt's Avatar
Originally Posted by RedXray
I came from the SBC, BBC and AMC engine building world with a few Olds, Buick, International and Ford builds here and there. The LS is a well designed platform and for me it was an easy intuitive assembly. The only quirk compared to any other platform is the number 5 main caps odd placement. The number 5 cap stamping goes on the opposite side. An easy mistake for first time LS builders that don't remember removal or don't have a manual. The other mistake is ordering the wrong head bolts as the newer gen3 (2003+) went to an equal length head bolt... and don't forget to install the barbell lol.
I've attached the LQ9 engine manual if you decide to build it yourself.
Number 5 main cap
Thank you very much for the info, the picture and the manual! Really appreciate the help.
Old Nov 19, 2020 | 11:09 PM
1FastBrick's Avatar
Not far from their.
You will get the most satisfaction from doing it yourself.
Old Nov 19, 2020 | 11:10 PM
I was just thinking, cylinder head shops might have good leads on engine builders. Check with-
West Coast Cylinder Heads (Van Nuys, Los Angeles County) - (818) 705-5454
BPE Racing Heads (Placentia, Orange County) - (714) 572-6072
Old Nov 25, 2020 | 01:59 PM
GarrettT/A's Avatar
Has anyone put these on a scale? Stock replacement flat tops with no balancing required would be nice.
Old Nov 25, 2020 | 02:18 PM
1FastBrick's Avatar
I can tell you my Friend is currently running .030 over's with the Floating pin rods on a stock crank that was originally Stock pistons with the early press pin rods.
Due I personally recommend it, No. But it can and has been done.
I paid through the nose and had mine balanced for piece of mind even though it was originally a floating pin rod motor. But I also had mine decked and torque plate honed too...
I have 1 Motor in front of it to get to first before I assemble it. I am not sure if mine was decked enough to get the piston near the top or out of the deck.
On my friends motor it was .009 Down in the hole With .030 Speed Pro pistons FWIW.
Old Nov 26, 2020 | 06:41 PM
GarrettT/A's Avatar
Thanks Brick, I may order a set and see where I end up. Although if they end up down on the hole that much that's not ideal either, were talking half a point.
Old Nov 27, 2020 | 12:52 AM
1FastBrick's Avatar
When they make replacement oversized pistons, They have to account for resurfacing and the change in bore size to maintain the factory compression ratio.
They don't take into account what we are doing.
An aftermarket replacement standard size piston may be the correct compression height. Someone would have to order one though to confirm.
Old Dec 3, 2020 | 04:33 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
The pistons are private label silvolite. Rings are private label hastings and bearings are private label king. Thats the long and short of it.
Old Dec 12, 2020 | 10:43 PM
LS CHEVY II's Avatar
I used the 5.3 set, 2010+ with 2 valve reliefs. Was disappointed in them when I only had 15 of the 16 wrist pin clips. Engine tech basically told me to **** off and to call who I bought them from. Then I called the seller (shop) and they said **** off call engine tech. Well FML, I had to use an old GM one to complete my build.
That type of customer service has pushed me away from ever giving engine tech another penny.
Old Dec 31, 2023 | 06:51 PM
southsliide's Avatar
Moresa Is the manufacturer for engine tech and a few other they are made in Mexico
Old Jan 2, 2024 | 10:16 AM
  #32
clay68c10's Avatar
Late to the party, but I couldn’t find info on this when I was looking.
The flat top engine tech 6.0 pistons are 20g heavier than the floating LQ4 stockers that were in my 04 engine.
The balance shop just had to weld metal back into some of the drilled areas of the counterweights. No Mallory metal needed.
Old Jan 2, 2024 | 08:17 PM
  #33
slowride's Avatar
Piston/pin combo or just piston comparison? Pins can be quite a bit different also.
Old Jan 3, 2024 | 09:48 AM
  #34
clay68c10's Avatar
It was the combo. The new piston was heavier and the new pin was lighter.
