LS1 newbies looking at casting# 12562374
Hi,
I'm converting from the German engine world and really enjoying it!
I'm considering buying an LS1 with a block casting number of 12562374. I looked all over and can't find the details for this block. Is there a master chart somewhere with all the LS numbers? This engine lost oil pressure and was immediately (i'm told) shut down. I will of course tear it down if I buy it so I would like to know what the specs are.
Thanks,
MosFetMan
Thanks,
MosFetMan
I have found 12562174 as an LS1 bock casting number. That is the closest to your number I have found.
Either way, LS1 blocks can't be bored more than .005 over the original 3.898.bore. So check the bores for any wear.
Block casting number is 12562174. Not sure where your seeing the xxxxx374 at...
