lm7 pushrod/cam
First new tools you should buy to help cure your n00bness are an adjustable push rod and a dial indicator. Comp 7702 is the most common adj PR around here. You can buy PRs in .025" length increments so that's the level of precision you need to work towards.
You will need to get good at finding the "heel" of cam lobes. Easiest way for me to get it REALLY ACCURATE is to look at the same valve in the cyl 4 cyls away in the firing order. Turn the crank until that one is at peak lift, then work on the ONE valve that is now at "zero". For example, to set #1 int on the "base circle", turn the crank until #6 int is full open (check its motion w dial indicator), put the adj PR in the #1 int spot, install the rocker arm, adjust the adj out in ½ turn (.025") increments until all of the VERTICAL play in the rocker is taken up, remove rocker, count how many turns out the adj PR is from all the way in, add .050" per turn to its fully screwed-in length (6.80" in the case of the 7702, and .050" because it's a ¼"-20 thread, therefore 20 threads per inch, therefore .050" per thread), add your desired preload to that number, buy. You'll have to know what the preload specs are for whatever lifters you're using. For example, if you had the adj screwed out 10½ turns, then your "zero lash" length would be 10½ × .050" or .525", added to the 6.8" which gives 7.325", if your lifters need .050" of preload add that to the 7.325, buy 7.375". DO NOT try to use the "twist the push rod" method for finding zero lash!! Jiggle UP AND DOWN looking for VERTICAL play ONLY. DO NOT try to measure the adj PR with a micrometer: the way they are spec'ed in the aftermarket IS NOT like that. Just follow the instructions I just gave you. I'd suggest doing at least the int & exh at the 4 corner cyls to make sure the same length will work for the whole motor. (might not, you know... might have to buy partial sets... probably not but you won't know until you measure)
Most often, the length of the adj push rod is most likely to come out to around 7.30 - 7.35", which will mean your motor wants push rods around 7.35 - 7.425". Stock length in aftermarket specs is 7.40". Note that I said "most often" and "most likely". This DOES NOT mean that yours will necessarily be in that range!!! Only, that most of the time for yerbasic stock motor that has an aftermarket cam and not many other mods, that's the most likely range for it to end up, that most of us who have worked on them have come up with most of the time. Yours might be different. I'd be suspicious if you came up with something ALOT different but who knows, until you measure it's all just guessing.
You can buy the 7702 and whatever length push rods, in .025" increments, at Texas Speed. You can get a cheeeeeep but entirely adequate dial indicator from lots of places; Horror Fake, McMaster-Carr, Summit Jegs etc., and so on. They're usually around $35 - 40 for example https://www.mcmaster.com/20715A44.
https://www.edelbrockspeedshop.com/E...FOR_p/2068.htm
1. Stage 4 5.3 Truck Cam 223/226 .600"/.600" Truck Camshaft, 111 LSA
2. Cleetus McFarland Dumpster Fire 224/228, .600"/.600", 114 LSA
which 1 would be better. i also plan on running 91 octane with a octane booster (97-100 octane) what would probaly be the max safe compression with spray
With forged internals, it should be able to handle at least a 200 shot. I have seen stock bottom end LS1s handle a 150 shot reliably. A forged 5.3-5.7 could probably handle whatever you plan on throwing at it.
1. no more more power is made or
2 i start apollo 18 with the internals
i mean completely stock. nothing exept for tuning
