Valve float
Did you get the newer "gold" springs? I know there were a few problems with their older dual springs...
Much worse in 2nd. It will take about 30 minutes at the most to put one in so go ahead n order one.
BTW I am running the same springs on a larger cam and it pulls all the way to 7000 where my limiter is set, I do have comp-r lifters tho. I shift at about 6700, Light is set at 6600.
Brad
