Ls9 cam
Old Jul 11, 2021 | 11:27 AM
Eric23_Z28's Avatar
Default Ls9 cam
So I recently got a ls9 cam and ls3 valve springs/pushrods for my 5.3 and was wondering if I will need a tune after the install or not since it’s a stock cam?
Old Jul 11, 2021 | 11:35 AM
It's a stock cam for a blown 6.2, and a lousy cam for an NA 5.3. You will LOSE power all the way up to over 5000 RPM. After that it gains a little power
IF you decide to use this turd of a cam, you will for sure need a tune.
Old Jul 11, 2021 | 11:47 AM
Eric23_Z28's Avatar
Lol it’s a budget build the ls9 cam is good for boost and I’m supercharging the 5.3 later (junkyard motor) I also got a good deal I know there’s better cams but for 3x the price.
Old Jul 11, 2021 | 12:12 PM
01CamaroSSTx's Avatar
Sell the cam and put that money towards the supercharger for the junkyard dog.
Old Jul 11, 2021 | 01:24 PM
Actually in a 5.3 the stock cam will be a better runner, even under boost.
As per Richard Holdener- ANY cam is a boost cam. And whatever characteristics it has NA, it will have under boost, only with more power. Under boost, the LS9 cam will add more power up top, but make less power at the bottom than the stock cam under boost.
Old Jul 11, 2021 | 01:50 PM
Eric23_Z28's Avatar
Was it really that bad when y’all ran this cam? Lol but I kinda already got it and it add some hp, If it’s that bad I’ll switch back when I supercharge it.
Old Jul 11, 2021 | 02:04 PM
The reason why? The LS9 cam performs with the better flowing heads and the larger bore.
Old Jul 11, 2021 | 02:34 PM
Eric23_Z28's Avatar
I got it cause I got a deal on the ls9 cam and valve springs I don’t really mind the low end for now but if it’s really bad I’ll buy a better cam when I boost it.
Old Jul 11, 2021 | 07:40 PM
ramairws6's Avatar
Don't do it you won't be happy. I have a 6.2 GMC 1500 with a blower on it and i hate that damn thing. It's like having nitrous on it after 3000 rpm but when your pulling it's absolutely worthless. Listen to the guys that know....
Old Jul 11, 2021 | 09:20 PM
68Formula's Avatar
Get the SDPC LS6 Power Max (currently ~$240). https://sdparts.com/i-24132276-sdpc-...6-0l-6-2l.html
Way better than an LS9 cam in a 5.3L NA (similar peak power, but with way more torque below 5000rpm). And it will work well with the blower too. And you can use the springs you already bought.
Old Jul 11, 2021 | 09:46 PM
Eric23_Z28's Avatar
Okay thanks I’ll definitely check it out since everyone saying the ls9 cam is not worth it and Will I still need the ls3 cam cover for the front cam sensor?
Old Jul 12, 2021 | 08:23 AM
68Formula's Avatar
It's a 3 bolt cam.
Old Jul 14, 2021 | 10:50 AM
CAMMOTION PERF's Avatar
LS1Tech Sponsor
You will definitely be disappointed with the LS9 cam in your 5.3. Get a used LS2 or LS3 (3 bolt version) or even an LS1/LQ9 cam if you are on a tight budget and you will be much better off.
Old Jul 15, 2021 | 09:12 AM
Jimbo1367's Avatar
Right from a cam company. oP need to check out Richard holdener’s videos
Old Jul 15, 2021 | 09:27 AM
Right from a cam company. OP needs to check out Richard Holdener’s videos
BIG 10-4 on this! I have learned TONS watching his videos. He is one of us!
Old Jul 15, 2021 | 10:04 AM
gagliano7's Avatar
https://www.motortrend.com/how-to/ls...st-comparison/
A lot of other stock cams that will perform better. The LS9 cam will be a turd driving around.
