Is this Ls1 engine noise normal?
Without pulling a cover you could even isolate where its coming from if you'll take an engine stethoscope or a long enough piece of rubber hose to put to your ear and listen to the engine. Hell even give it some throttle if needed.
After I came back from the drive I did put a hollow broomstick up to the valve cover, just below the hollow part of the cover, right on the bolt, and heard distinct ticking sounds at each cylinder location, they were all exactly the same and sounded normal to me. That leads me to believe that's not where the issue is.
Will try the same broomstick trick on a cold engine...
Edit: tried listening with a broomstick when cold, sounds fine.
However! While driving around I stopped at a coffee shop near another car, and I could hear a quite loud ticking bouncing back either from the coffee shop wall or the car beside me. A minute later tried to replicate it and NO sound...this ******* car is driving me insane!
