Texas Speed Heads Question on Compression
I have an email in to Speed Engineering, hopefully they will return it or call in the morning. Thank you for the info and appreciate the help.
TRUE DUAL CM-F9302-TD
This is what I found from for the true duals crossmember.
https://ls1tech.com/forums/suspensio...rear-exit.html
Post #10 Has picks and info from Midwest
I spoke to Corvette Connection who does a lot of our F body work and tuning in Colorado (only 3 shops out here), They said the speed engineering headers isn't the tightest fit, and the ARH's fit better in their opinion. I like the pricing of Speed E. headers better, but definitely like the idea of good fitment, as the car sits low already. Might look into ARH headers and the Speed Engineering true duals as the combo to go with. Will know more after talking with them tomorrow.
Sounds like Headers are 3-4 weeks out from being made, which I am in no rush for, but appreciate Mike looking into it and communicating, after all the push rod conversations the past few weeks, thought it would it would be a good idea to get a push rod length checker.
Talking with Martin Smallwood, with the .040 thousandths head gaskets and 243 heads milled to 62-63cc's should land me in the 11.1-11.3 compression ratio.
I talked with Danny M. Owner of Bowtie engine shop on what he recommended on oil pump, timing chains, and head bolts or studs, he is easily one of the premier engine builders in this area and I trust his opinion, I have known him over 20 years, his son Eric won Las Vegas Outlaw 235 a few years back, glad to have local knowledge like that around.
1 x LS Series Melling Oil Pump (High Pressure) (10295)
1 x 98-02 LS1 RPM Speed Single Heavy Duty Timing Set (RPM-HDTS)
2 x 98-02 LS1 RPM Speed Cylinder Head Bolt Kit (One Head) (12498545-X)
2 x 98-02 LS1 Cometic MLS 3.910" Head Gasket (.040") (C5475-040)
1 x 98-02 LS1 Camshaft Installation Kit (GMCAMKIT)
1 x 1998-2002 American Racing Header 1-7/8" x 3 (LS1R-98178300HR)
1 x 1998-2002 American Racing 3" x 2-3/4" Y-Pipe No Cats (LS1R-98300234YPNC)
1 x COMP Cams Hi-Tech Pushrod Length Checking Tool (7702-1)
Will keep everyone updated as things start progressing. Hopefully the 243 Heads land at TEA today.
