Texas Speed Heads Question on Compression
Came across TSP Small Bore heads, and it gives options on combustion chamber sizing, understanding that stock ls1 241 heads are between 67-68cc and that puts overall engine compression around 10.1-1. What size combustion chamber would get me around the 11.1 range? I am sure there is a calculator out there I couldn't find, was hoping Texas Speed might chime in or some one who might know could throw out some numbers. I appreciate the help.
https://www.texas-speed.com/p-1163-p...der-heads.aspx
Kind of looks like 62cc might be the ticket
BTR Stage 3 (231/244 .630"/.615") https://briantooleyracing.com/btr-ca...3.html#reviews
I saw you mentioned the MSD Atomic, how do you like that intake?
I've made 600 rwhp with a n/a 416ci and prc 247cc cathedrals and a msd atomic in an fbody.
If you dont mind me picking your brain a little, what about the BTR cams do you not like? Just the dyno numbers, or what specifically?
416ci making 600whp would be a pretty cool and fun car!
MS3 238/242 .600"/.600" 112.0
MS4 239/242 .649"/.600" 111.5
BTR 3 231/244 .630"/.615" 112.5
I see you are talking about the cam motion LLSR, I'll have to jump in and do some research on that, a few things have changed since last time I was building LS cars.
TSP, then BTR.... anyone see a pattern here?? Lingenfelter next? But their grinds are nearly prehistoric, so maybe not...
Mavn, I appreciate the heads up you have given on HP / dyno numbers, I am not saying that's everything, but a lot of archive digging has shown down on power numbers or cars peaking at 56-5800 rpms (given these were 2016 posts) but I haven't seen any post that I could find or research I could find that supports the 450hp that camshaft states with good heads and supporting mods.
Definitely still want my hot rod power tour cross country car, just want a little more power than 360hp, but don't want to sacrifice drivability.
https://www.texas-speed.com/p-1150-t...-camshaft.aspx
For off the shelf cams, and that criteria, I think a Cam Motion Titan IV or roughly similar ~ 228/232 type cam is worth thinking about. However that's a much too generic sort of cam for social media or cool factor heroics and a well done custom spec would probably be a bit better.
Cam Motion Titan IV
Grind # XA227/360-XA232/350-13+4
Hydraulic Roller Camshaft
Aggressive Performance
Duration at .050": 227/232
113 Lobe Center Angle with a 109 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .612"/.595"
Recommended Displacement: 5.3-6.2 Liter Engines
Cylinder Heads: Cathedral Port
Recommended Compression Ratio: 9.4.0-11.5:1
Mavn- appreciate the discussion on TSP ramps vs BTR ramps that is definitely something I brought up and wanted better understanding of, so thanks for the input on that.
Most of the guru benefit would probably be in tweaks like lobe selection for valve train longevity, how much advance to grind in and best LSA etc...and feeling like all the bases had been covered
