E1839P cam ls1
Hello
The camshaft with high quality ,and one year warranty.The stainless steel material is very durable.
As the picture shows
Lydia
The camshaft is hardened to withstand durability or the new designed roller cams correct? and wont eat into the cam lobes like an an old style solid cam?Your previous message
Run from this and buy from reputable dealers.
Likewise, would use LS1Tech market place to find a cam or used cam over fleabay etc.
dear customer
thanks for your message
the item is our own brand not the elgin
it can replace the elgin directly
for now, we don't have the picture of the box it ships in.
Hi,
Thank you for your inquiry.
This is an aftermarket one. Sorry it won't fit 99 year.
Best
Goldie
Buy from reputable dealers/distributors/manufacturers.
None of the people you quoted above can be trusted any further than you can throw them, especially Lydia or Goldie, which are not names many Chinese parents name their kids.
Look at the structure of their sentences. English is their second language.... a DISTANT second...
BTR WEEKEND WARRIOR CAM KIT (briantooleyracing.com)
BTR GEN III & IV WEEKEND WARRIOR CAM - STAGE 3 - 31824133R1
218/224 .553/.553 113+3
would it be best to start a new thread related to this? Its about the same as the elgin 1838 1839 cams.
KMJperformance has the elgin E1839P for around 236$ on ebay. Either the weekend warrior for 249$ or elgin with a set of pac 1218s or are the .560 BTR springs adequate enough for his weekend warrior but DAILY DRIVEN corvette in terms of say 50k miles?
Melling has something similar to the elgin .223/.223 catalog More Information for MELLING 22201 (rockauto.com)
Hi Justin,
If it’s not advertised as Elgin, then it’s probably not Elgin. We are an actual factory, we cannot sell retail.
For cams, the E-1840-P / Sloppy Stage 2 is the most popular. Adds 60 hp to a 4.8/5.3 with only swapped springs, should need a converter, tune required. The 1840 in a 6.0/6.2, will work great with turbo, supercharger, nitrous too. We have several customers making 1000+ whp with this cam. Supposedly the 1838 & 1839 will work with a stock tune. There’s lots of feedback that the 1838 is a great daily driver with very similar off-the-line throttle response, plus added top end power. The 1200 series cams are OE GM grinds with descriptions included below.
E-1838-P : C : Sloppy Stage 1
E-1839-P : C : Secret Sauce X
E-1840-P : D : Sloppy Stage 2
E-1841-P : D : Sloppy Stage 3
The 1800 series cams have a stock base-circle, so a stock length push rod is fine if all other components are also stock.
A quick note on torque converter stall speed: the generic power range of the E-1840-p is 2200-5400 rpm (even though it has proven to continue to produce power beyond 7000 with power adders.) Most street-builds ususally end up with a 22-2500 stall speed. However, there is some engineering that goes into stall speed selection, and that is best recommended by a converter company. Other than cam and trans info, they are going to need to know:
Stall Speed Info Needed:
Vehicle Weight
Axle Gear Ratio
Tire Size
I had copy and pasted certain stuff from the email elgin sent me. Im thinking of there E-1839-P Secret Sauce X cam with 286/282 220/224 112lsa .575/.575
Seems like it would work with the stock converter nicely on a 3250lb 99 c5 corvette with tsp headers, CAI, 3.15 gears.
The BTR weekend warrior is a little low on lift .553/.553 but i think would make good power for a daily driven corvette. This should help in regards to the knock off ebay advertisements with a diff base circle and or reground cam. These cams are around the 240$-260$ price range new so would cover the pac 1218s with a nice set of 1 piece pushrods. It may be able to run on the stock tune for a while once it relearns until i can afford a tune.
