Anyone using Morel 7717 Lifters? Preload?
Anyone using the Morel 7717 lifters? What preload did you use? I'm using an iron block (lsx) with ls3 aluminum heads (821). I've read where people said .060, .040, .035, etc. So not sure lol
Wild guess is I'm around 45 to 50 with the iron block & aluminum heads combo...idk
The 7717’s were previously the 6504’s. Not exactly sure why Morel changed the numbers and I won’t type heresay or rumors. The lifters have .120” of plunger travel. You’ll likely find preload info under the previous 6504 part number. Morel changed the number earlier this year if I remember right.
The following users liked this post:
01CamaroSSTx (12-06-2021)
Im thinking to go with about 40 since I have an iron block and aluminum heads...
LS1Tech Sponsor
Received 1,231 Likes
Btw, as a heads up, we now offer the Morell 7717 as our part number SUM-HT217-16 lifter
Could you tell us if there is any changes internally on the lifter from the morel 6504's to 7717's?
What I was getting at is, if replacing a 6504 lifter with a 7717 no change in pushrod length will be required, correct?
momofx (01-05-2022)
LS1Tech Sponsor
