LS1 upgrade list
Old Dec 13, 2021 | 08:57 AM
imaswfan's Avatar
Default LS1 upgrade list
Alright so I have a 4th gen Fbody trans am that I知 looking to trick out but still be steerable and not a drag only car, follow this will be the full list so far and the reason I知 posting is I知 asking if there痴 anything I知 missing or need along with everything, think I知 only lacking in the fuel department now, feel free to suggest things! I知 a noob. Ignore the huge font and prices, that was just for personal reference lol
COMPLETE BOLT ONS
Fast Toys Ram Air Kit FTRA 1998-2002 Camaro & Firebird $200
https://fasttoys.net/shop/catalog/Fast-Toys-Ram-Air-Kit-FTRA-1998-2002-Camaro-Firebird-p-1.html
LSXR 102mm Intake Manifold for LS1/LS2/LS6 $974 from FAST
https://www.fuelairspark.com/lsxr-102mm-intake-manifold-ls1-ls2-ls6.html
Nick Williams Performance Throttle Body 102mm Drive by Wire (LS1, LS2, LS3, LS7) $705
https://www.tpsmotorsports.com/nick-williams-performance-throttle-body-102mm-drive-by-wire-ls1-ls2-ls3-ls7.html
2000 Pontiac Firebird DeWitts 1998-2002 Camaro/Firebird Direct Fit 2 Row Radiator (Low Level & Oil Connection) Auto Trans $669.99
https://www.texas-speed.com/p-10678-dewitts-1998-2002-camarofirebird-direct-fit-2-row-radiator-low-level-oil-connection-auto-trans.aspx
2000 Pontiac Firebird Texas Speed 100mm Mass Air Flow Sensor $286
https://www.texas-speed.com/p-660-texas-speed-100mm-mass-air-flow-sensor.aspx
2000 Pontiac Firebird TSP 98-02 Camaro & Firebird 2.00" Long Tube Headers With 3.00" Collectors - 304 Stainless Steel $666.99
https://www.texas-speed.com/p-4908-tsp-98-02-camaro-firebird-200-long-tube-headers-with-300-collectors-304-stainless-steel.aspx
1998 - 2002 FOR Camaro Trans Am STAINLESS TRUE DUALS 3" X PIPE DUMPED LS1 SS Z28 $294
https://www.ebay.com/itm/151106131274?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=151106131274&targetid=12630940033 86&device=c&mktype=&googleloc=9026243&poi=&campaig nid=14859008593&mkgroupid=130497710760&rlsatarget= pla-1263094003386&abcId=9300678&merchantid=108134507&g clid=CjwKCAiAtdGNBhAmEiwAWxGcUrUQz00b5_X_3qefIJlSV lL2-ep6E0jd3WCePUXZeePl2xvDpYUgCRoCEy0QAvD_BwE
98-02 LS1 ASP Racing 25% Underdrive Crank/Alternator Pulleys $256
http://www.ws6project.com/user_stor/catalog/98-02-ls1-asp-racing-25-underdrive-crank-alternator-pulleys/
2000 Pontiac Firebird ACCEL - FUEL INJECTOR - 48 LB/HR - USCAR - HIGH IMPEDANCE - 8 PACK $382.95
https://www.texas-speed.com/p-10850-accel-fuel-injector-48-lbhr-uscar-high-impedance-8-pack.aspx
CAMSHAFT AND SUPPORTING
Summit Racing SUM-8707R1 - Summit Racingョ Pro LS Automotive Camshafts $300
https://www.summitracing.com/parts/sum-8707r1
COMP Cams 13702-KIT - COMP Cams GM LS Series Retrofit Trunnion Kits $147
https://www.summitracing.com/parts/cca-13702-kit
Trick Flow Specialties TFS-2500286P - Trick Flowョ Double Platinum .660 LS Dual Valve Spring and Retainer Kits $231
https://www.summitracing.com/parts/tfs-2500286p
Summit Racing SUM-14917400 - Summit Racingョ HDR Thickwall Chromoly Pushrods $155
https://www.summitracing.com/parts/sum-14917400#overview
Summit Racing SME-143012 - Summit Racingョ LS2 Timing Chains $30
https://www.summitracing.com/parts/sme-143012
2000 Pontiac Firebird GM High Performance LS Oil Pump, Wet Sump $80 with o ring
https://www.texas-speed.com/p-5111-gm-high-performance-ls-oil-pump-wet-sump.aspx
https://www.texas-speed.com/p-11115-moroso-oil-pump-o-ring-pack-for-ls-car-or-truck.aspx
Summit Racing SUM-G2704-10 - Summit Racingョ Torque Converters $360
https://www.summitracing.com/parts/sum-g2704-10
SUSPENSION/CHASSIS
Power Stop K1548 - Power Stop Z23 Evolution Sport Brake Upgrade Kits $315
https://www.summitracing.com/parts/pwr-k1548/make/pontiac/model/firebird/year/2000
BMR Suspension SFC023R - BMR Subframe Connectors $269.95
https://www.summitracing.com/parts/bmr-sfc023r/make/pontiac/model/firebird/year/2000
BMR Suspension TA001H - BMR Xtreme Torque Arms $289.95
https://www.summitracing.com/parts/BMR-TA001H
BMR Suspension KHP003R - BMR Level 3 Suspension Handling Packages $1589
https://www.summitracing.com/parts/bmr-khp003r
BMR Suspension PHR002R - BMR Suspension Panhard Bars $129.95
https://www.summitracing.com/parts/bmr-phr002r/make/pontiac/model/firebird/year/2000
Strange 12 Bolt F-Body Street Rear End With Eaton 33 Spline Truetrack Differential For 1993-2002 Camaro, Firebird, & T/A With ABS $2910
https://www.strangeengineering.net/product/12-bolt-f-body-rear-end-for-abs-brakes.html/
Old Dec 13, 2021 | 10:59 AM
99 Black Bird T/A's Avatar
Yes, it will be steerable.
As to if it will be STREET-able, depends on the tuners skill or lack of skill.
BTW - 4th Gen LS cars use drive by cable throttle bodies with the factory PCM. You have a drive by wire Nick Williams listed for ~$700 the Nick Williams drive by cable is normally less than ~$400
A lot of part selection depends on what you want to do with the car.
A Procharger or MagnaCharger might be a better choice than heads, cam & intake for an LS1.The HCI project described sounds like ~$4,500 more than half the cost of a Procharger or MagnaCharger. Either can make more power, be more streetable and be used with other motors more easily.
My selection of parts would be radically different for a newly acquired 4th Gen LS car. I mostly focused on maintenance and making absolutely sure the car is in excellent mechanical condition before spending any mod money. Usually 5,000 miles of daily driving and doing ALL maintenance, all fluids etc will reveal what sort of car one has to work with.
Nothing quite sucks like putting a new torque converter in an old transmission that's seen better days etc. Or buying a 12 bolt when the 10 bolt was in great shape and might have lasted 300 1/4 mile passes at the drag strip in an A4 car. Have seen some 10 bolts go 400+ passes at the strip and some break on the street due to wheel hop.
I picked up a 238k mile Z28 turned out car was in outstanding mechanical condition, good cosmetic condition so the Z28 ended up as the new daily driver except for winter time. A lot of the initially planned mod's like new radiator, engine swap, rear end swap proved unneeded etc Almost four years and now 256k miles nearly issue free.
Old Dec 13, 2021 | 11:40 AM
imaswfan's Avatar
thanks so much! That痴 a lot of good info, I already had the car fully checked by pros and they said for the 140k miles they were surprised with how well it was maintained, they changed out a bunch of bushings and other suspension pieces that go bad with a 21 year old car, so your saying with the pro charger or the magna, I wouldn稚 have to do the cam heads and intake? That sure would save a whole lot 😪 also, how much power do you think I値l be pushing with the HCI compared to the pro charger or magnacharger
Old Dec 13, 2021 | 02:41 PM
YOKED's Avatar
Your post has a ton of gray area. What's streetable for some may not be for others. With that said, here are a few pearls:
Fast intake should be ported for maximum gains. Tony Mamo would be a good start for such.
That cam will pull for days. Comp has a drift cam that will also pull and rev for days. Many ways to skin a cat. No matter what you decide to do, a good set of heads serves as a great foundation for ANY project. Some force induction guys might tell you otherwise however don't believe the hype. Heads + force induction make more power everywhere.
Bang for the buck you can't beat a supercharger. Nitrous will work very well with your 2" LT headers. Depending on which way you go will decide converter stall speed.
Fuel wise: you have not stated how much power you are attempting to achieve. For starters, a 340lph pump should be good for 700rwhp which allows for future expansion. Remove regulator in tank (will save you labor time in the future.)
There's no mention of lifters. Your budget will dictate which one you choose.
BTW, ditch the MAF and go SD.
As highlighted above, get a great tuner for best results preferably on a mustang dyno.
There's so much more that goes into making a good combo and a great combo. More time deciding purpose of car will help you have a better experience once everything is put together. Hopefully this gets you going in the right direction.
Old Dec 13, 2021 | 06:07 PM
Lot of it is personal preference and budget. Personally I like affordable stock ported heads and cam packages and MagnaChargers
Affordable ($4,000 to $4,500) HCI packages with ported stock heads, Fast intake depending on cam choice and tune...400whp to 450whp are pretty doable maxing out a stock fuel system that's in excellent condition.
Expensive ($7,000+) Aftermarket heads, full roller rockers, low lash solid roller cam, ported Fast or MSD intake, true dual exhaust, quality aftermarket lifters electric water pumps, crank scrapper, etc. 450 whp to ~535 whp...depending on cam and how much over 7,000 rpm one is willing to go
Procharger $6,500 about 400whp if rings in motor are worn out to ~650 whp on stock short block in good condition for a while with cam & fuel system upgrades. Can make ~1,400+ hp etc
MagnaCharger $7,500 simpler install depending on supporting mods like cam and fuel system etc 450whp to ~650whp. Hard to push past ~700whp usually. Instant power at low rpm.
Old Dec 13, 2021 | 08:26 PM
imaswfan's Avatar
thanks so much man, really good info! And on heads, what if I threw some ported junkyard ls6 heads on? I致e heard you can find them pretty cheap compared to brand new
Old Dec 13, 2021 | 08:27 PM
imaswfan's Avatar
thank you!
Old Dec 13, 2021 | 08:29 PM
wannafbody's Avatar
A Procharger might be nicer than a big **** cam to drive. Stock cam will work fine and 243 heads are a $500 upgrade.
Old Dec 14, 2021 | 06:22 AM
LS6/243/799 - basically same head casting. Used prices ~$400 to $500 typically. Porting, valve springs, valves etc typically $1,000 to $1,500 depending on what you want.
No idea if these are still available new. AFR has a stock replacement offered now days to fill that niche.
TEA ported versions in fully optimized LS1/LS6 engines have made 500whp to 520whp with all the expensive supporting mod's.
Even stock LS6/243/799's with new valve spring kit these heads unported, typically give nice gain with a fat cam (231/236 duration) on an LS1 if your willing to spin the rpm.
It's easy to end up with $1,600 to $1,800 buying and having ported LS6/243/799's. Many folks choose a set of as cast Trick Flows for a little more money.
706/862 - aka 5.3 heads - basically same head casting after porting. 706 semi permanent mold slightly superior to 862 before porting.. Used prices ~$200 typically. Porting, valve springs, valves etc typically $1,300 depending on what you want. Texas Speed sells/sold them out right no core charge for ~$1,350
241's - stock head on 2001-2002 model year LS1. Less powerful than the two listed above due to big chamber and lower compression. Seldom used these days. Advanced Induction had a nice welded up version that raised compression. More expensive than 5.3's and typically less effective.
Old Dec 14, 2021 | 09:17 AM
quiet_storm98's Avatar
as someone that has had 2 head and cam fbodies I would personally just go straight to a procharger, in the end having a head and cam car gets kinda boring once you get used to the power and it gets expensive once you start to add everything up. That being said a head and cam car is easy to maintain and will still be quick enough to beat a lot of things you will run into on the street.
Old Dec 14, 2021 | 10:10 AM
QuietStorm makes an excellent point. Plus with the coming of the EV's, forced Induction looks even better for older gas cars.
