LM7 pistons and rods
The WS6 Store has several complete kits for that sort of rebuild. I think the rods were separate. Hopefully, this will help with a rough idea. There are several versions of the kit and they can tailor it to your need etc.
WS6 Store - RPM Speed LS Complete Engine Rebuild Kit
There normally isnt a reason to go with forged, especially if youre not going to make sure the bore is straight, but also for even 500 to 600 hp, the stock or stock style pistons seem to work just fine and dont have an issue sorting rods. Just gap the rings for your intended goals and make sure the tune is good.
Also, DO NOT BORE THE BLOCK BEFORE YOU HAVE THE PISTONS, but also DO NOT ORDER THE PISTONS BEFORE YOUR MACHINE SHOP CHECKS BLOCK OUT.
We have customers do BOTH this year even though it was recommended against on the phone and they had to wait to swap pistons out. Do the foot work first so you can get it all done at once without issue.
