Help with part number ?
Old Feb 19, 2022 | 09:39 AM
Budco's Avatar
Default Help with part number ?
Does anyone have a part number for the intake bolt grommets on a 2002 LM7 ? The only grommets I could find were for the valve covers. Any help would be appreciated.
Thanks....
Old Feb 19, 2022 | 10:29 AM
I just googled "LS intake manifold bolt grommet" and it took me to Amazon where a set of bolts with grommets and crush sleeves is available. ACDelco also has them. I did not see grommets available separately anywhere.
All that aside, many guys just re-use the bolts w/grommets and CORRECTLY torque them.
Old Feb 19, 2022 | 10:34 AM
Metalchipper's Avatar
Hello,
Bolt, grommet and spacer
GM GENUINE 89017368
Rock Auto has them
Old Feb 19, 2022 | 10:45 AM
Budco's Avatar
I've seen multiple places with the bolt/grommet but that's a waste of money to me when I don't need bolts.
Old Feb 19, 2022 | 11:07 AM
Did you save the old grommets and crush sleeves? If so, reuse them.
You can't buy them separately, apparently. It looks like they come as an assembly, available for about $20/set.
Cheap at twice the price.
Old Feb 19, 2022 | 11:37 AM
Budco's Avatar
Where did you see $20 a set, cheapest I found them was $80 a set. Thanks
Old Feb 19, 2022 | 11:55 AM
theunderlord's Avatar
Originally Posted by Metalchipper
Hello,
GM GENUINE 89017368
Rock Auto has them
google that part number.
Old Feb 19, 2022 | 01:47 PM
RB04Av's Avatar
The way that whole system works is, the bolt tightens down against the spacer, compressing the grommet, which acts like a spring. The grommet applies the correct pressure on the manifold, according to the length of the spacer, no matter how tight you tighten the bolt, thereby eliminating any possibility of breaking the manifold. (well, that's the idea anyway, no doubt some people still sometimes manage to break the manifold somehow) In fact I suppose it might even be possible to replace it with a spring. Not that there would be any reason to do so, but w/e. Regardless, not really the kind of thing that needs replacing much, unless you destroy them somehow or throw them away or lose them or something like that. The only thing that torquing the bolt "correctly" does is, get the bolt tight enough to not back out, while not getting it SO tight that the threads strip or that it breaks off. (yes people do manage to accomplish those things from time to time) Not a matter of the torque "correctly" compressing the grommet.
The valve covers work the exact same way. Might even be the same grommet for all I know (never paid attention), or at least substitutable.
Old Feb 19, 2022 | 03:53 PM
GM Parts Center.
$21.79
Old Feb 23, 2022 | 09:55 AM
gagliano7's Avatar
You have to buy two sets since only 5 come in a package and you need 10.
