HeAd gAsKeT SiZeS.
Old Mar 8, 2022 | 11:06 PM
plcrides's Avatar
Default HeAd gAsKeT SiZeS.
hey guys so when i did my swap by myself in 2021 i had never touched a ls style engine,so the header bolts are smaller than my old chevy truck with a sbc crate engine in it and i broke off a bolt and had to remove the head.i didnt know since no one was helping me that when i replaced the head gasket. size matters haha or so i guess,i saw on hotrod garage he was building a motor for boost and he said something about head gasket size and since then ive seen it around online so back when i did my swap heres what i did and didnt know anything until here lately and started wondering i bought a felpro,heres the part # fel-26192pt
and it shows on summits web site the bore is 4.100 in.
the compressed thickness is 0.048 in.
the ac delco gasket on oreillys is and im not sure if thats what is on the engine stock.
the bore 4.110 in.
the gasket thickness doesnt say compressed is 0.072 in.
so this is on my pass/side the felpro.will this do anything ? did i screw up guys ? or will it not be noticable i hope.those were the only two numbers i could get.
Old Mar 9, 2022 | 07:29 AM
wssix99's Avatar
Save the manuals!
Moving thread to Internal Engine.
@plcrides - Please confirm the exact type model of engine you are working with.
Old Mar 9, 2022 | 07:50 PM
plcrides's Avatar
oh shoot,sorry guys,its a 2011 silverado 2500 hd 6.0 L96
Old Mar 9, 2022 | 09:13 PM
jetech's Avatar
Veteran: Air Force
Perfectly fine choice of head gasket
Old Mar 9, 2022 | 10:55 PM
So to clarify, you only changed one side headgasket, or did you replace both sides?
Old Mar 9, 2022 | 10:59 PM
So to clarify, you only changed one side head gasket, or did you replace both sides?
If he uses the .072 gasket mentioned, he will lose a ton of compression.
Old Mar 9, 2022 | 11:25 PM
plcrides's Avatar
i had to remove the one head due to broken header bolt,so i replaced gasket on one head,the gasket i got is a felpro
fel-26192pt and the numbers of the thickness were found on summit for that one,
i dont know the exact gasket that came stock or the thickness. on summit it says the compressed thickness is 0.048 in.for the one i bought the felpro
so i looked at the head gasket on oreillys a ac delco assuming thats what came with the engine,but im not sure,and on oreillys their ac delco gasket just gave a thickness of 0.072 but this didnt say compressed.
with my luck i probably am losing compression or something. guess i need to find compressed thickness for head gasket on 2011 L96 somehow ?
do you guys think im losing compression on the one side ? thanks for the replies
Old Mar 9, 2022 | 11:41 PM
plcrides's Avatar
so long story short the gasket i put on one side is 0.048 compressed
i looked online and it looks like the stock gasket is 0.051
im not sure if thats compressed or not though.so am i screwed ? does anyone know if thats compressed or thickness before it goes in on a L96 6.0
Old Mar 9, 2022 | 11:42 PM
theunderlord's Avatar
I got you dude. (you edited, you sneaky.....)
Click here
GM Head Gasket Part Number 12610046 fits most 2007 and later GEN4 6.0L and 6.2L LS engines.
This part number is the stock replacement head gasket for 6.2L LS3, L92, L99, L94, and L9H engines. It is also the factory replacement head gasket for these 6.0L engines - L76, L96, L77, LC8, and LY6.
The compressed thickness of this gasket is approximately 0.051" and it a multi-layer steel design.
Old Mar 10, 2022 | 06:13 AM
Your looking at compressed numbers. Are you screwed? No. How long have you been running it like this, or have you ran it at all?
Old Mar 10, 2022 | 07:22 AM
plcrides's Avatar
with all the transmission swapping ive done ive ran it about 750 to 800 miles since the summer of 2021 maybe just a little bit more.but not a thousand.thanks for the help guys,so the big question,what do i do,i was just getting it ready to start driving.is it hurting anything.0.048 compared to 0.051 on the other head ? god i cant believe this.
Old Mar 10, 2022 | 08:02 AM
Mavn's Avatar
"I MAID THEESE"
You're fine it'll last 100k miles like that
Old Mar 10, 2022 | 08:52 AM
plcrides's Avatar
oh man well thats good news,kinda lol.thanks guys for all the speedy replies.and Mavn im just north of houston in montgomery,i grew up on the north side of houston.thats funny out of the whole country.to be honest im not really happy with the way it runs.but i hate the thought of having to tear it all back down to a bare block.i guess i will start looking at heads and see what kind of difference they would make.thanks again i have the ls3 style low profile intake so i would want something to work with that.
Old Mar 10, 2022 | 01:33 PM
jetech's Avatar
Veteran: Air Force
GM factory replacement head gasket I think the passenger side bank of cylinders will have an increase in compression of about .06 :1 unless I missed something
