LS1 Block ID
Old Mar 28, 2022 | 02:02 PM
Austin.VQ's Avatar
Default LS1 Block ID
Ive tried to track down an answer but not having alot of luck searching the forums.
I have been told there are differences in the blocks between the LS1 years.
Im not sure where to look to identify this block. If anyone can point me in the right direction it would be great.
Old Mar 28, 2022 | 03:31 PM
theunderlord's Avatar
on the front drivers side the displacement should be cast in there, and the date code should be on front of the block in front of the passenger cylinder head surface.
https://www.onallcylinders.com/2017/...ads-cam-specs/
Old Mar 28, 2022 | 04:03 PM
Austin.VQ's Avatar
Unable to find that.
this is the only noticeable numbers.
Old Mar 28, 2022 | 04:42 PM
Austin.VQ's Avatar
dont have any casting marks there. Just have this
Old Mar 29, 2022 | 08:19 AM
KCS's Avatar
KCS
Moderator
At first glance, if it is a 5.7L block, it looks like an LS6 block. it doesn’t have that column in the valley like the LS1 blocks do.
Are you sure there are no casting numbers? Double check the back of the block around where the bellhousing bolts on. It should be one of these two spots.
Old Mar 29, 2022 | 09:16 AM
Austin.VQ's Avatar
what is that arrow pointing to?
at work currently will check again when i get back home. May have to scrub that area.
Old Mar 29, 2022 | 09:28 AM
KCS's Avatar
KCS
Moderator
It’s pointing to a little column that was cast into the old LS1 blocks. It’s significant because you had to cut it down to fit an LS6 valley cover on them. Heres another photo from an old “how-to” article.
Like I said in the other thread you have going, some of the other photos of the block show some things that make it look like it’s actually a 5.3L block.
Old Mar 29, 2022 | 10:51 AM
Austin.VQ's Avatar
Found this
If I remember correctly the design of the backside here means it’s after a 98
Old Mar 29, 2022 | 12:08 PM
https://ls1tech.com/forums/generatio...hat-block.html
"12560626"
there you go.
