First build, looking for some guidance.
I would like to start off by apologizing if I go over topics that have already been covered or questions that are already answered. I was hoping to kind of gather all my info here in order to help me make decisions.
I am going to be building a LQ4, its going in to my 00 Silverado 2500 4x4. I work as a contractor so I would still like some utility out of my vehicle but I want to give her some extra ponies.
I dont necessarily have a goal as far as HP goes, but somewhere in the 400-450 range would be awesome. I want to run the stock rotating assembly, or at least crank and rods. I have not decided whether or not boring it out is worth the effort for my application. I will be replacing all the bearings in the bottom end.
So here is what I have come up with so far; I want to run 706 heads, found some CNC ported for a good deal, I figured the slight bump in compression wouldnt hurt anything and add power to everything over the whole curve. The company I am going to purchase from also has a set of CNC ported 823 heads, any opinions on these over the 706 heads, both being ported?
I would like to run either TBSS intake or LS2 intake, or an aftermarket one in the same $ range. I know the Fast LSXR is probably better but its not really within my budget.
I believe Ive also decided on sticking with the stock rockers and doing the trunnion upgrade. From what Ive heard, that will support my power goals no problem.
Now this has been the real tricky part for me, the cam. Ive watched hours of Richard Holdener and I think the sloppy stage 2 cam he uses is what Id like to use, as in his tests in increased both torque and HP numbers across the board with no losses. I think this is an area where I could really use expert advice, as I dont want to go way over on what is necessary for my power goals, but I also dont want to skimp on my cam selection.
I currently have 35 tires on 3.73 gearing, but Im going to be upgrading to 4.56. My transmission is a 4l80e, which Ive heard is good for 400-500HP.
Going to keep the standard oil pump as well. Injectors were a question but I think Id need be I could use the 8.1 injectors.
That is essentially all Ive gathered for myself, I wanted to get the opinions of people who have done this before me instead of just going hog wild on ordering parts. I appreciate all the advice and suggestions you guys can give me. Thanks in advance.
It sounds like you want to build a 6.0L on a budget and you need it to still work as a truck. So as for an intake, you want a TBSS. But don't go on ebay and buy one. I mean you can if you want to throw money away. You being from Michigan you have an advantage of being in a state with a good selection of U pull it style junk yards. Most of these yards charge a flat price for any "intake manifold" or "cylinder head". So you are going to go there and find a 4.8L or a 5.3L that is a 2005 or newer. 2007+ if it's an Express van. These motors (mostly) came with 243/799 heads and a good number of them had TBSS intake manifolds from the factory. The last time I bought heads and an intake from a U pull it junk yard I spent $125 for everything. These heads will flow the same as the 317's that your LQ4 has on it. But they will bump your compression up.
The sloppy stage 2 cam would be a horrible choice for a work truck. For one you need to swap in a higher stall converter for that cam. That will cause issues with towing and hauling. The SS 2 cam is great in a car or a truck that isn't used as a truck. What you want to look at would be the Summit Racing LS truck cams. These are purpose made for what you're trying to do. I don't know if you would make 400 hp to the tire with a setup like this. But it would be a nice jump from stock and should be close.
As far as injectors go when you're at the junkyard getting your heads and intake, take a look and see if the vehicle you pulled the parts from was flex fuel. If it was then keep the injectors from that motor. They will flow around 36 lb/hr and would be plenty big for a NA pump gas 6.0L
The biggest issue you face in this is tuning. You have to figure out if you're going to take a stab at it yourself or take it to a pro. Also how are you going to tune it? HP tuners, PCM hammer, Holley? But if you don't have any way of tuning it I wouldn't start it with a factory tune. Tow the thing to a shop or worst case have a mail order tune done.
I don't know if any of this helps. I'm sure others here will have different advice for you. But one things for sure, this forum has a lot of very knowledgeable people who like to help. Use the search function and you will find a wealth of information here.
Also check out this guys youtube channel. He's also from Michigan. He talks about where he goes to pull parts in a lot of his videos.
https://www.youtube.com/c/TheDrivewayEngineer
Good luck!
Regarding Stock Rocker Arms, I'd leave the rocker arms alone unless you find one going bad. In real life, I have know one person that had issues with a stock LS1 rocker arm bearings in 24 years. It was on a 98 Trans Am. One rocker arm scattered needle bearings when the car was like two years old and two year later another rocker was discovered going bad on a cam install. I've know of two dozen plus + LS engines with 250,000+ miles on the stock rockers and no issues. I think the internet blows the needle bearings failures out of proportion. Of course any worn out parts should be replaced.
Seen two sets of trunnion upgraded rocker arms done by "professionals" that I could feel the bind in the rocker arm trunnion 😳.
If you feel you must upgrade the trunnion avoid Comp Cams upgrade kit there gave been many issues in the past. CHE, BTR, Cstraub and a few others seem good when installed correctly.
Not a fan of 317's NA, great for boost however.
As for cams, the Truck Norris cam seems all the rage these days. The dyno results look good. That might be worthwhile to research.
Good luck!
Overall it seems like TBSS intake is the way to go for me.
For my application are you meaning to say just a set of 243/799 without any milling would be plenty of increase in flow?
The cam still is my biggest issue here, cause im torn between calling it my work truck and where I really draw that line. I tow with it maybe 1-2 times every 2-3 months, and nothing really over 6,000lbs. Ive never driven anything other than a diesel with over 350HP while towing so I really have no idea how it would perform.
As for those injectors, I hadnt heard that, but thats good to know. Ill definitely pull them if I come across any!
I wanted to take a crack at HPtuners, but that may be too ambitious for my first time. I know my way around computers but the tuning aspect of it I have no idea what Im looking at.
Also thank you for providing that channel, Ill check him out and see what good yards are near me.
Sounds like everyone is suggesting the TBSS intake, thats the route Ill go.
The current LQ4 I have in my truck has 275k miles on it and she still purrs. Granted things may look a little different inside but oh well, hasnt quit on me yet. Rocker arms have been the iffy area for me, have seen and read so many different things.
Heads I will be replacing no matter what, I want the possibility of adding more power in the future, but N/A power.
Ill take a look at that cam, see what its all about. Thanks for the info!
If it wont run me backwards in search of power, the cnc ported heads I looked at have a smaller combustion chamber, I cant remember exactly if they were 66 or 68, but the 317 heads had like 71.04. I am more than willing to spend money here. Aftermarket heads are pretty much sold out from everywhere I looked, and double what these heads I found are. I can include a link if youd like to see them.
Im not afraid to spend some money on it, I just dont want to waste money on parts I dont need. I would love the capability to throw more power at it in the future if possible, cause I may end up just getting another truck/van for work purposes.
EDIT: Forgot to mention that the 823 heads I found have slightly larger intake and exhaust valves than 317 heads.
I’m not afraid to spend some money on it, I just don’t want to waste money on parts I don’t need. I would love the capability to throw more power at it in the future if possible, cause I may end up just getting another truck/van for work purposes.
Also the 243/799 heads are 64cc so depending on your head gasket that should put your compression around 10.4:1. You could get that lower with a thicker gasket. I'm running a LQ9 with flat top pistons and a factory gasket. That puts me at almost 11:1.
Alrighty Ill look in to that, will save me a bunch of money.
i thought about going with LQ9 pistons before but I wasnt sure if the extra compression would end up hurting anything that was left stock.
