Pushrod question
I was able to get the intake valve on the base circle. I used a trick flow measuring tool (which is 6.8 at its lowest).
At 12.5 turns i could rock the rocker ever so slightly for a very very tiny click. At 12.75 turns it was stiff and I was unable to rock it at all. I double checked both of those measurements.
So am I correct in saying the math goes as such:
(12.75x.05)+6.8=7.4375
Then I take that number and add the desired preload, correct? Which for the Johnson 2110R should be approx .050 because after heating up it that would bring it to a desired .035 preload. So the Pushrods should be 7.4875.
Am I doing this right? Never done anything like this before. I know the lifters aren't full of oil so they could depress some too ..
Thank you. So it sure seems I did everything right except I could have possibly depressed the plunger during my measurement.
exhaust was 7.35
I ordered eight 7.475 pushrods for the intake which gives .0375 preload which is a tiny hair less than I would have liked.
I ordered eight 7.40 pushrods for the exhaust which gives .050 preload
It's the closest I was able to get without going custom or ordering heavily backordered parts.
I used the Comp Cams pushrod length checker, and the measurements I got were true to measuring with a caliper. When you order them, a lot of times they are sold as "gauge" length, which is a little longer than measured with a caliper.
I ordered 7.400" and received 7.412", which actually ended up perfect for what i needed.
Edit: every engine is different, but I normally see intake and exhaust pushrods pretty close in length. My last one was +/- .005" from longest to shortest.
Will report back if I have any problems, but I hope I'm all set. Pushrods will be here today and car should be road worthy this weekend.
At any rate, that .012” longer is actually a good thing.
I just measured up an LS1 with 243’s cut .035”.
Ordered 7.375” pushrods. At install I noted approx 1.25 turns of the rocker bolt from 0 to full preload. Right in the ballpark.
The Johnson’s may have a different cup height than other lifters. Never used them, just a guess.
In Tyler’s case, perhaps the valve stem heights ended up different from intake to exh due to the valve job, or non stock valves.?
They def are different than a standard LS7 lifter. These specifically are short travel lifters. As far as I know the valves are stock. I paid for a stage 1 job which uses stock valves.
I have read several posts about the short travel Johnsons requiring different length pushrods. My only concern at this time is that I feel like I need to go back and measure every single one... painstaking process lol
Cylinder 2 intake 7.475 rod exhaust 7.4 rod
cylinder 3 intake 7.4 rod exhaust 7.4 rod
I'm starting to wonder if I compressed the lifter in the intake side of cylinder 2 and it didnt spring back up all the way. Thoughts?
Planning on measuring all remaining cylinders tomorrow. I know some people are like...just throw them in! Well I'm a very thorough person so I want this done right 100%.
Insert a rod in the exhaust valve. Rotate the engine until I feel that rod start to come up. Take the measuring tool and start measuring the intake valve. Vice versa for the exhaust valve.
Every pushrod will be either a 7.4 or 7.375
EXCEPT cylinder 2's Intake (previously mentioned above) and cylinder 6's exhaust will require the longer 7.475 for some odd reason...
All the preloads will be within spec, with the lowest being .0375 and highest .050
Woohoo... time to put it together.
