Pushrod - major difference between exhaust and intake lengths
Long story short I had to yank the heads to throw in new INTAKE valves. I also swapped scorpion rockers and am going to be using a trunion gm set.
I have everything back together and am measuring out the pushrod lengths to verify I don’t have anymore pvc issues.
I set the INTAKE valves to zero lash and throw in the old 7.4 pushrods and can tighten 1 - 1 1/8 turns before it’s seated.
The EXHAUST valve however (which I didn’t mess with) set at zero lash will only turn an 1/8 of a turn after setting lash. I’ve verified multiple cylinders all with the same result.
Based on the pushrod length checker 7.75 length pushrod for exhaust side 🤨
What’s the problem here???
