Gen 3 5.3 will not turn over
Spins nice and good until the 3 bolts get torqued. Then cam is pulled too tight against retaining plate and won't spin. Its the cam bearing face rubbing the inside of the retaining plate. Looks like the the cam needs more length so it hits the sprocket before face of bearing hits the retaining plate.
This is the sprocket used.
If so, that might be your problem.
Show us the factory cam sprocket next to your new one, from the back.
The new cam's nose is sized for a retainer plate about half as thick as the old one is. No idea why a cam would be that different from a stock one. I do note that your new one is set up for a 3rd gen w rear-block cam sensor, where the one you took out is a later one; butt I can't see where that matters. I'm not aware that the retainers are any different for the 2 applications.
I'd recommend sending that pic to whoever the cam came from and see what they tell you. Gut says you'll be getting another cam in the mail.
Because you're showing us two incompatible parts.
Just show us a picture of the cam and sprocket In the same shot
Certainly seems like nose is too short, if was longer would hit sprocket before retaining plate and be good... i think.
When I get home I do have a stock gto camshaft to check it against and see which nose is the odd ball. My stock one or new one.
I don't really have a micrometer to measure it out but maybe .005 thinner than gap between cam and sprocket should work.
