Gen 3 5.3 will not turn over
Old Jul 29, 2022 | 10:17 AM
jwise850's Avatar
Default Gen 3 5.3 will not turn over
Motor is on the stand and will not turn over by had after I install the timing chain. I can losen the cam sprocket bolts and it will turn over fine. It’s like after they are torqued to 26#s it snugs the camshaft timing gear to the cam retainer and will not turn over.
I’ve changed retainer plates twice. And this is my second timing chain set. Any advice will be greatly appreciated!
Old Jul 29, 2022 | 01:07 PM
Old Buzzard's Avatar
bolts screwing into the retainer?
Old Jul 29, 2022 | 01:26 PM
jwise850's Avatar
Yes sir. It’s the new style with countersunk bolts
Old Jul 29, 2022 | 02:22 PM
jasons69chevelle's Avatar
Did you install the thrust bearing?
is the timing sprocket machined for a bearing?
Old Jul 29, 2022 | 02:47 PM
jwise850's Avatar
So It did not come with a thrust bearing. I’m unsure how to tell if it’s machined for one so here’s a few pics. Could one be added?
Old Jul 29, 2022 | 03:18 PM
That one isn’t machined for the bearing. Have you installed just the sprocket onto the cam to verify clearance. Without the chain
I’d switch to a timing chain set that includes a thrust bearing, if you do that make sure you install the bearing properly it does have a certain direction it installs, but will install wrong causing wear.
Summit racing part number
SUM-G6640
Old Jul 29, 2022 | 03:27 PM
jwise850's Avatar
Do you recommend any?
Old Jul 29, 2022 | 03:32 PM
I used
Cloyes Race Billet True Z-Racing Roller Timing Sets 9-3672TX9Z
but that summit one will work just fine.
Old Jul 29, 2022 | 03:41 PM
jwise850's Avatar
Thanks! I completely overlooked the summit one you posted
Old Jul 29, 2022 | 03:44 PM
jwise850's Avatar
It is weird though I have cam play front to back but it’s like the cam doesn’t stick out the depth of the cam gear
Old Jul 29, 2022 | 03:55 PM
Might be worth getting a GM cam retainer plate if that’s not a factory plate.
Old Jul 29, 2022 | 08:01 PM
1FastBrick's Avatar
where is the cam from?
It doesn't look like its sticking out enough. but photos can be deceiving.
Old Jul 29, 2022 | 08:38 PM
jwise850's Avatar
It’s an englin cam
Old Jul 29, 2022 | 09:07 PM
Do you have camshaft endplay with the sprocket bolted on? Leave the chain off, and bolt the sprocket on the camshaft. I bet you’ll find your problem there.
Old Jul 29, 2022 | 09:25 PM
jwise850's Avatar
None it snugs up to the cam retainer at 26ftlbs and then the cam wont spin at all. Do u think the cam is junk? Cut wrong?
Old Jul 30, 2022 | 05:43 AM
What does the new gear look like compared to the one you took off?
How does the ft brg width of the old cam compare to the new one?
Old Jul 30, 2022 | 08:36 AM
jwise850's Avatar
I think I'm going to pull the cam and check the lengths. Do u think this would be a good idea? I have the new retainer plate ordered to give that a try.
Old Jul 30, 2022 | 12:19 PM
grinder11's Avatar
You did what I think Che70velle was saying, but you're saying it differently. Anyway, sounds like the timing gear is bottoming against the plate, or Block. If you have some dykem blue, or some paint, like red or blue, something easily seen, brush a light coat on the retainer plate AND block. SLOWLY....torque the gear/sprocket down, to try and determine how tight it has to be before it binds up. Check for binding at certain intervals. When it starts binding, turn the gear with maybe an oil filter wrench, or some sort of strap wrench, to protect the teeth. Then remove the gear, and inspect the paint for galling.......
Old Jul 30, 2022 | 04:14 PM
jwise850's Avatar
Definitely good ideA! Hope to mess with it tomorrow! Thanks guys!
Old Aug 3, 2022 | 06:18 PM
jwise850's Avatar
New gm cam retainer and it’s still binding down
