Keep breaking valve springs but only on passenger side
The following users liked this post:
2Heavy4Fast (09-18-2022)
Turbobuick6 and Che70velle gave excellent advice. My question is, who did the valve job? Just because they were new from the manufacturer (if they were) means nothing. I broke a spring once on a brand new AFR head that someone at AFR screwed up the installed height from the get go. You can have a spring good for .800", but if it can only make .700" lift before coil bind (also known as stacking), it doesn't matter. Turbo works at PAC, so Id pay close attention to what he advises. There's also this; I may be old school, but to me, Melling is pumps, and PAC is springs. In other words, if PAC makes a pump, I'm still going with Melling. If Melling makes springs, I'm still going with PAC. My train of thought isn't limited to just these two companies. I'm sure you can see where I'm coming from. IMHO, it sounds like the valve job is all over the place for installed height, or possibly the cam grinder screwed up. Best of luck to you.....
The following 2 users liked this post by grinder11:
2Heavy4Fast (09-18-2022), G Atsma (09-16-2022)
What was your measured installed height? If I am reading the correctly, you were at 1.750" installed height?
It's possible the seats are grossly mis matched on depth.
I had a go-around with this once ,, had two heads fully rebuilt for a dune buggy, (VW)
When I got them from eh sop you could see with your eyes they were about .1 inch different depth..
Shop claimed you just use the tappet adjustment to match them..
Took a in person chat to get my money back.
Next shop had to redo both and weld one to get them the same.
Thank goodness they were cheap stockers..
The following 2 users liked this post by pdxmotorhead:
Sure thing. I've lurked here for a while and have come to really appreciate it when people take the time to update so that the next person who comes along with the same issue can definitively narrow down a likely solution. Now that the account is made though, I plan on frequenting back to hopefully be able to help some other people too if I come across some questions/problems that I have experience with. I keep finding this place to be a HUGE wealth of knowledge, no matter how much time someone has spent holding a wrench. Thanks again for the help!
The following 2 users liked this post by 2Heavy4Fast:
Che70velle (09-19-2022), rednari2 (09-20-2022)
I actually JUST madea comment about that right before I saw your comment. Turns out that the seats weren't all the height, thus causing my spring install height to vary too much OEM tolerances. The banks 1 head was fine, but since I had to go with higher lift springs on bank 2, I had to switch out the others that that weren't wrong, too.
