ls1 knock/tick
Old Oct 6, 2022 | 01:15 PM
Ayden's Avatar
Default ls1 knock/tick
Would anyone be able to give me any ideas of what this is sounds like maybe a valve spring?
File Type: mov
Old Oct 6, 2022 | 01:33 PM
Exhaust leak. As it slows in the end you can hear gasses escaping.
Old Oct 6, 2022 | 01:48 PM
Ayden's Avatar
would that explain the engine sound too?
Old Oct 6, 2022 | 01:52 PM
In the video I'm not hearing any mechanical sounds. Might be the video.
I'm just hearing sharp, staccato high pressure escaping gas sounds. Again, maybe the video.
Old Oct 6, 2022 | 06:11 PM
Pull the valve covers and see if the pushrods are all moving when running. She’s hurt.
Old Oct 6, 2022 | 06:53 PM
01CamaroSSTx's Avatar
Inspect your belt and pulleys before anything else.
Old Oct 6, 2022 | 07:00 PM
Darth_V8r's Avatar
Moderator
I can hear it when hot gases escape from my butt...
The motor however, I'd suspect a bent connecting rod. It's too fast to be top end. Exhaust ticks tend to be at half speed, like lifter ticks. Although, as CamaroSSTX said, I'd check externally for something rattling against the serpentine belt or a pulley.
Old Oct 6, 2022 | 07:06 PM
Just played thru a better speaker. VERY mechanical. My bad. Yeah, this thing's hurt....
Old Oct 6, 2022 | 09:50 PM
Ayden's Avatar
I still have perfect oil pressure as well
