View Poll Results: Best Choice for Engine Project
#1 AI heads & EPS Cam on stock LS1
7.14%
#2 383 LS1 Stroker, S2 TEA 706's, EPS cam
14.29%
#3 404 LS2 Stroker, GMPP LS6, 239/244 cam
25.00%
#4 Sell parts and buy HotCam LS3 crate engine
28.57%
#5 see comments for a much better idea
25.00%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Best choice for engine project?
Old Oct 14, 2022 | 09:48 PM
  #61
99 Black Bird T/A's Avatar
Thank you, Yes, same 02 Z28.
Old Oct 15, 2022 | 10:25 PM
  #62
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by showdog75
Use the ls2 block for the 402 and do yourself a huge favor and hit the Tony Mamo easy button. Let him tell you which of his heads to use and let him port a Fast 102 and also spec the cam. You'll have some money in it but it'll hit harder than that ls3 crate engine ever thought about. With a baby cam to boot.
Damn.....that was pretty good!!
OK Showdog....we will have to discount some product your way.....let me know what I can help you with!!
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old Nov 11, 2022 | 07:47 AM
  #63
showdog75's Avatar
Well... any updates on this project?
Old Nov 12, 2022 | 05:29 AM
  #64
No, an unexpected wiring harness issue(s) and a couple of other gremlins with my LS swapped 91RS back burnered the 02 Z28 plans for a while.
Old Jan 8, 2023 | 09:35 AM
  #65
z-maro's Avatar
Have you nursed the '91 back to health? All that talk about using the 226/230 cam, mamo 102, and a ported factory cathedral port head on a 400+ LS2 has me anxious to see some numbers! I finally found a decent deal on a used rear end, so by spring I should have a S60 w/ 4.10s installed, and hope to get some track times on my 226/230, mamo 102, and AI 232 LS1 combo without fear of needing a tow home due to a busted 10 bolt.
