24x reluctor wheel issues
We measured the overall runout of the reluctor just below the teeth and found it to have about .024" runout which is more than .010" over what thompson stated it had in the paperwork provided with the engine, however the issue I see is there are several teeth that are bent or "laid over" slightly which you can see by just looking at it as it spins over. One tooth was bent .010" in one direction and the next corresponding tooth was .011" in the opposite direction, and the two halves of the wheel have varying gap between them as you spin it over and appears to be "wavy". Looks like someone smacked the wheel near the teeth in a few spots to align the reluctor either before or after welding it..and where it is welded the 2 piece wheel shows a larger gap between both halves. This might be splitting hairs here but I'd like to know what the true tolerance is for these reluctors becuase GM states no more than .010" and aftermarket crank manufactures state the sensors will operate with up to .040" runout...so which is it?? All i know is I measured the reluctor in the old LS1 and it appears dead straight and only has .004" runout. In either case the engine is going back to Thompson for them to inspect it and most likely replace the reluctor, I spoke with them about using a billet 24x reluctor wheel instead of the factory 2 piece design so I don't have this issue again, but does anyone have experience with this problem or have used a billet wheel before? Is it worth the extra cost? Let me know your thoughts as this has been extremely frustrating. Thanks!
You can get the crank out with the pistons and rods still in but pushed even with the deck. It’s a big job but easier than trying to tweak it and hope it’s ok after reinstalling the engine.
Sometimes, straightened parts can return to their bent state. For the low cost involved, and especially with the motor out, Ron is 100% correct. Wouldnt be worth my time gambling if a new one is $30-$50, and I think their much less than that. Then you know what you've got. I'm 99% certain this is the issue. Question for OP; is your car an A4? Ron knows where I'm going with this one!!
I had a 2002 Tahoe spontaneously shutting off for a half a second and come back on and would sometimes misfire at idle and finally completely died . Ended up being a broken crank sensor wire about 24 inches from where it connects to the sensor, was still in wire loom wrapped with tape, even the wire insulation was still intact just wire broke inside.
