pump gas truck 8.5 DCR OR DCR Including Elevation
so im looking at a ls1 (5.7) street truck app dangerously close to 8.5 DCR.
Question is can i include elevation in my calculations and go off that to see what i can get by with???
the initial combo looks like this 4,700 lbs DCR 8.46:1 and 8.32:1 at elevation .
if i can just go off 8.32 i can breathe a little easier.
thoughts on minimum grades of gas?
thanks Tim
thanks Tim
the initial combo looks like this 4,700 lbs DCR 8.46:1 and 8.38 :1 at elevation .
if i can just go off 8.38 i can breathe a little easier.
thanks Tim
thanks Tim
The following users liked this post:
jeepfun_tj (01-28-2023)
thanks Tim
thanks Tim
jeepfun_tj (12-28-2022)
The newer 355 hp 5.3L runs on 87 and is ~11:1. My mom has a newer Titan that has a slightly detuned version of the ~420 hp 5.6L engine that was in my M56S. It has 11.2:1 static compression with right at 400 hp and it was tuned to tow 9,600 lbs on 87 octane. That truck gets 22-23 mpg highway. The more compression you can get away with the better your mileage and power will be.
Great insight! the examples of Your iron head combo vs aluminum vs a stock set-up was really helpful! more and more people keep going with higher and higher and higher DCR on the street. i kind o wonder why so many tuners used to set a hard limit @ 8.5 DCR with premium gas?
Is it over time ideas are expanded or is it differences with setups or maybe ECM's are faster and reluctors have more teeth etc
THOUGHTS? I only bring it up as im running a 98' ls1 with a 24 tooth wheel
much thanks to everyone
The following 2 users liked this post by bobcratch:
G Atsma (01-24-2023), jeepfun_tj (01-25-2023)
